itk:hsio [2016/06/27 18:22] mazhang [HSIO-2 characterization station] |
itk:hsio [2017/02/03 23:11] asc |
Line 1: | Line 1: | ||
- | Useful links: | + | |
* [[https:// | * [[https:// | ||
Line 8: | Line 6: | ||
* [[Using Ethernet Connection to HSIO-2 Board and WiFi Simultaneously]] | * [[Using Ethernet Connection to HSIO-2 Board and WiFi Simultaneously]] | ||
* [[Changing IP Address of Attached Device]] | * [[Changing IP Address of Attached Device]] | ||
- | * [[Installing | + | * [[Installing |
+ | * [[Installing Local Linux Server | ||
+ | * [[Installing Pixel Testing Software]] | ||
+ | ====== Calibration with HSIO ====== | ||
+ | * [[Calibration with HSIO]] | ||
+ | ====== User's Guide ====== | ||
+ | * [[Using the Pixel Application]] | ||
+ | * [[Performing Pixel Calibration]] | ||
* [[Glossary]] | * [[Glossary]] | ||
+ | * [[Extracting channels from ROOT files]] |
