itk:testbeam [2016/09/30 13:48] asc [Conclusions:] |
itk:testbeam [2016/09/30 18:05] asc |
Line 1: | Line 1: | ||
- | (prepared | + | (some notes by S.Chekanov) |
Here are the useful links on test beam in Sep. 2016 at SLAC. The plan is discuses | Here are the useful links on test beam in Sep. 2016 at SLAC. The plan is discuses | ||
- | What is used: 11 GeV secondary electrons (~100 - 200 per bunch), 5 HZ frequency. Original electron beam is 14 GeV. | + | What is used: 11 GeV secondary electrons (~10-100 |
+ | The beam sport is about 1x1 cm (tunable). | ||
+ | Original electron beam is 14 GeV. | ||
The setup is described in [[https:// | The setup is described in [[https:// | ||
To start the run, use: | To start the run, use: | ||
Line 27: | Line 29: | ||
* Readout ASIC with 65 nm (vs 130 nm for FE-4IB). This decrease of ASIC leads to smaller sizes. | * Readout ASIC with 65 nm (vs 130 nm for FE-4IB). This decrease of ASIC leads to smaller sizes. | ||
+ | Here is the setup at the end-station A: | ||
- | ====== How to make calibration | + | This is the RTI module (uncovered): |
+ | This is the RTI module + RD53 prototype (uncovered): | ||
+ | Telescope: | ||
+ | Control room upstairs: | ||
+ | ====== How to calibrate the module | ||
Line 133: | Line 152: | ||
+ | Note large number of low occupancy channels (40 counts instead 50). Right after installing this module, we had 99% of fully efficient channels.. | ||
Line 153: | Line 174: | ||
Line 174: | Line 195: | ||
- | Both modules from RTI have shown signs of degradation performance. After about ~6-8h, we start to see problems for the analog | + | Both modules from RTI have shown signs of degradation |
- | channels. The occupancy for uncalibrated module goes from 99% to 70% after 6h. The noise increases by a factor 2. | + | |
+ | This problem is not related to the active beam, since the red module was not under the beam on Sep 28. | ||
- | This problem is not related to the active beam, since the red module was not under the beam in Sep 28. | ||
