itk:testbeam [2016/09/30 17:25] asc |
itk:testbeam [2016/10/04 15:11] asc |
Line 1: | Line 1: | ||
- | (prepared | + | (some notes by S.Chekanov) |
Here are the useful links on test beam in Sep. 2016 at SLAC. The plan is discuses | Here are the useful links on test beam in Sep. 2016 at SLAC. The plan is discuses | ||
- | What is used: 11 GeV secondary electrons (~100 - 200 per bunch), 5 HZ frequency. Original electron beam is 14 GeV. | + | What is used: 11 GeV secondary electrons (~10-100 |
+ | The beam sport is about 1x1 cm (tunable). | ||
+ | Original electron beam is 14 GeV. | ||
The setup is described in [[https:// | The setup is described in [[https:// | ||
To start the run, use: | To start the run, use: | ||
Line 19: | Line 21: | ||
Details on 2 tests: | Details on 2 tests: | ||
- | 1) Testing RTI (USA vendor) to test bum bonding. | + | 1) Testing RTI (USA vendor) to test bump bonding. |
Line 28: | Line 30: | ||
Here is the setup at the end-station A: | Here is the setup at the end-station A: | ||
+ | This is the RTI module (uncovered): | ||
+ | This is the RTI module + RD53 prototype (uncovered): | ||
+ | Telescope: | ||
+ | Control room upstairs: | ||
====== How to calibrate the module ====== | ====== How to calibrate the module ====== | ||
Line 183: | Line 195: | ||
- | Both modules from RTI have shown signs of degradation performance. After about ~6-8h, we start to see problems for the analog | + | Both modules from RTI have shown signs of degradation |
- | channels. The occupancy for uncalibrated module goes from 99% to 70% after 6h. The noise increases by a factor 2. | + | |
+ | This problem is not related to the active beam, since the red module was not under the beam on Sep 28. | ||
- | This problem is not related to the active beam, since the red module was not under the beam in Sep 28. | ||
