itk:testbeam_febmi2017 [2017/03/21 23:12] dfrizzell [Calibration section] |
itk:testbeam_febmi2017 [2017/04/06 15:21] asc [Location] |
Line 4: | Line 4: | ||
The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | ||
- | We will attempt to test RTI module | + | <fc # |
A outline of the sample test schedule is here https:// | A outline of the sample test schedule is here https:// | ||
+ | A living document for operating the telescope can be found here: | ||
+ | https:// | ||
====== Current Status ====== | ====== Current Status ====== | ||
- | Waiting for roof Repairs. | + | Updated Last: Apr 4 10:00pm |
- | ===== Open Access | + | |
- | They plan to use different particle species and we may be a week without good beam, at least if we want to run during the day. They expect to be done as early as Friday. Monday will be roof repairs and there will not be beam for anywhere from 1/2-3 days ===== | + | |
+ | Taking data. We have cooling system " | ||
====== Argonne Equipment at FTBF Inventory List ====== | ====== Argonne Equipment at FTBF Inventory List ====== | ||
Line 25: | Line 24: | ||
* Bertan 380N HV power supply in crate | * Bertan 380N HV power supply in crate | ||
* Chiller Plate + fittings and hose | * Chiller Plate + fittings and hose | ||
+ | * Single Chip Card with bare FEI4 | ||
====== Available equipment at TestBeam area ====== | ====== Available equipment at TestBeam area ====== | ||
Line 97: | Line 97: | ||
The data is being exported to the eos file system here: | The data is being exported to the eos file system here: | ||
+ | To mount eos, do this: | ||
+ | mkdir eos; eosmount eos | ||
+ | The data can also be found at the ANL cluster: | ||
For information on updating the data from fermilab local files see ' | For information on updating the data from fermilab local files see ' | ||
https:// | https:// | ||
Line 108: | Line 122: | ||
There is a working proteus distro at : | There is a working proteus distro at : | ||
+ | Analysis code with Fermilab beam configuration can be found at: | ||
+ | Preliminary results of this code can be found at : | ||
Can also be obtained from gitlab instructions found at : | Can also be obtained from gitlab instructions found at : | ||
Line 173: | Line 193: | ||
svn co svn+ssh:// | svn co svn+ssh:// | ||
+ | The current setup (March 24, 2017) looks as this: | ||
==== Calibration section ==== | ==== Calibration section ==== | ||
Requires the flowing figures in the EPS format plus ROOT files. Please attach these ROOT files to this wiki. | Requires the flowing figures in the EPS format plus ROOT files. Please attach these ROOT files to this wiki. | ||
Line 205: | Line 233: | ||
These plots can be found on argon servers here: | These plots can be found on argon servers here: | ||
==== Results ==== | ==== Results ==== | ||
Plots for 120 GeV protons. The module should be calibrated to 3000e without the BEAM. | Plots for 120 GeV protons. The module should be calibrated to 3000e without the BEAM. |
