itk:testbeam_febmi2017 [2017/03/25 22:13] dfrizzell [Current Status] |
itk:testbeam_febmi2017 [2017/04/06 02:16] dfrizzell [Current Status] |
Line 4: | Line 4: | ||
The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | ||
+ | <fc # | ||
A outline of the sample test schedule is here https:// | A outline of the sample test schedule is here https:// | ||
- | A work in progress | + | A living document |
https:// | https:// | ||
====== Current Status ====== | ====== Current Status ====== | ||
- | Taking data, despite DCS issues. We are forced to power the Car Board from external Power supply. | + | Updated Last: Apr 4 10:00pm |
+ | Taking data. We have cooling system " | ||
====== Argonne Equipment at FTBF Inventory List ====== | ====== Argonne Equipment at FTBF Inventory List ====== | ||
Line 22: | Line 24: | ||
* Bertan 380N HV power supply in crate | * Bertan 380N HV power supply in crate | ||
* Chiller Plate + fittings and hose | * Chiller Plate + fittings and hose | ||
+ | * Single Chip Card with bare FEI4 | ||
====== Available equipment at TestBeam area ====== | ====== Available equipment at TestBeam area ====== | ||
Line 105: | Line 108: | ||
There is a working proteus distro at : | There is a working proteus distro at : | ||
+ | Analysis code with Fermilab beam configuration can be found at: | ||
+ | Preliminary results of this code can be found at : | ||
Can also be obtained from gitlab instructions found at : | Can also be obtained from gitlab instructions found at : |
