itk:testbeam_febmi2017 [2017/03/29 20:18] rwang [Testbeam at Fermilab (2017)] |
itk:testbeam_febmi2017 [2017/04/06 15:21] asc [Location] |
Line 4: | Line 4: | ||
The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva | ||
- | <fc # | + | <fc # |
A outline of the sample test schedule is here https:// | A outline of the sample test schedule is here https:// | ||
Line 11: | Line 11: | ||
https:// | https:// | ||
====== Current Status ====== | ====== Current Status ====== | ||
- | Updated Last: Mar 27 10:40 | + | Updated Last: Apr 4 |
- | No Beam, Pump down until 13:00. | + | |
+ | Taking data. We have cooling system " | ||
====== Argonne Equipment at FTBF Inventory List ====== | ====== Argonne Equipment at FTBF Inventory List ====== | ||
Line 23: | Line 24: | ||
* Bertan 380N HV power supply in crate | * Bertan 380N HV power supply in crate | ||
* Chiller Plate + fittings and hose | * Chiller Plate + fittings and hose | ||
+ | * Single Chip Card with bare FEI4 | ||
====== Available equipment at TestBeam area ====== | ====== Available equipment at TestBeam area ====== | ||
Line 95: | Line 97: | ||
The data is being exported to the eos file system here: | The data is being exported to the eos file system here: | ||
+ | To mount eos, do this: | ||
+ | mkdir eos; eosmount eos | ||
+ | The data can also be found at the ANL cluster: | ||
For information on updating the data from fermilab local files see ' | For information on updating the data from fermilab local files see ' | ||
Line 107: | Line 123: | ||
- | Preliminary analysis | + | Analysis code with Fermilab beam configuration |
+ | Preliminary results of this code can be found at : | ||
Can also be obtained from gitlab instructions found at : | Can also be obtained from gitlab instructions found at : |
