itk:using_ethernet_connection_to_hsio-2_board_and_wifi_simultaneously [2016/05/25 21:15] mazhang |
itk:using_ethernet_connection_to_hsio-2_board_and_wifi_simultaneously [2016/05/26 16:48] mazhang |
Line 1: | Line 1: | ||
+ | ====== Using Ethernet Connection to HSIO-2 Board and WiFi Simultaneously ====== | ||
When using an ethernet cable to hook up a computer with the HSIO-2 board, you may find that your wi-fi connection stops working. The reason for this is that your computer thinks both the wi-fi and ethernet connection are methods of connecting to the internet. As ethernet is generally faster than wi-fi, the computer will automatically ignore the wi-fi and start trying to use the ethernet port for internet stuff. The HSIO-2 board receives this info, doesn' | When using an ethernet cable to hook up a computer with the HSIO-2 board, you may find that your wi-fi connection stops working. The reason for this is that your computer thinks both the wi-fi and ethernet connection are methods of connecting to the internet. As ethernet is generally faster than wi-fi, the computer will automatically ignore the wi-fi and start trying to use the ethernet port for internet stuff. The HSIO-2 board receives this info, doesn' | ||
Line 6: | Line 8: | ||
Kernel IP routing table | Kernel IP routing table | ||
Destination | Destination | ||
- | 0.0.0.0 | + | 0.0.0.0 |
0.0.0.0 | 0.0.0.0 | ||
1.1.1.1 | 1.1.1.1 | ||
130.202.2.0 | 130.202.2.0 | ||
- | 192.168.1.0 | + | 192.168.3.0 |
192.168.122.0 | 192.168.122.0 | ||
- | If you want to learn about networking and IP addresses and things like that, [[http:// | + | If you want to learn about networking and IP addresses and things like that, [[http:// |
- | route del default gw 192.168.1.1 | + | < |
- | route add default gw 192.168.1.1 metric 1000 | + | route del default gw 192.168.3.1 |
+ | route add default gw 192.168.3.1 metric 1000 | ||
Now if we look at our connections again with: < | Now if we look at our connections again with: < | ||
Line 25: | Line 29: | ||
+ | This needs to be done every time you connect the ethernet cable. |
