itk:using_ethernet_connection_to_hsio-2_board_and_wifi_simultaneously [2016/05/25 21:18] mazhang |
itk:using_ethernet_connection_to_hsio-2_board_and_wifi_simultaneously [2016/05/26 16:05] mazhang |
Line 16: | Line 16: | ||
- | If you want to learn about networking and IP addresses and things like that, [[http:// | + | If you want to learn about networking and IP addresses and things like that, [[http:// |
route del default gw 192.168.1.1 | route del default gw 192.168.1.1 | ||
route add default gw 192.168.1.1 metric 1000 | route add default gw 192.168.1.1 metric 1000 | ||
Now if we look at our connections again with: < | Now if we look at our connections again with: < | ||
Line 33: | Line 35: | ||
192.168.122.0 | 192.168.122.0 | ||
+ | This needs to be done every time you connect the ethernet cable. |
