User Tools
Site Tools
lcrc:introduction
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
lcrc:introduction [2019/01/22 14:42]
asc [Using Singularity]
lcrc:introduction [2023/04/27 19:18]
asc [Using Singularity for cvmfsexec]
Line 108: Line 108:
 <code bash> <code bash>
-srun --pty -p  bdwall  -t 24:00:00 /bin/bash+srun --pty -p  bdwall   -A condo -t 24:00:00 /bin/bash
 </code> </code>
Line 131: Line 131:
 To run on non HEP nodes use partition bdwall with Account - ATLAS-HEP-group To run on non HEP nodes use partition bdwall with Account - ATLAS-HEP-group
 +==== Using interactive jobs ====
 +First, allocate a HEP node:
 +<code bash>
 +salloc -N 1 -p hepd -A condo  -t 00:30:00
 +</code>
 +This allocates it for 30 min, but you can allocate it up to 7 days.
 +You cam also allocate it on bebob:
 +<code bash>
 +salloc -N 1 -p bdwall --account=ATLAS-HEP-group -t 00:30:00
 +</code>
 +This does not login you!
 +Check what node did you allocate
 +<code bash>
 +squeue -u user
 +</code>
 +Now you know the node. Then login to bebob (first!) and then ssh to this node.
 +Another method is to use
 +<code bash>
 +srun --pty -p  bdwall  --account=ATLAS-HEP-group -t 00:30:00  /bin/bash
 +</code>
 +=== Running long interactive jobs ===
 +See more description in: https://www.lcrc.anl.gov/for-users/using-lcrc/running-jobs/running-jobs-on-bebop/
 +You should be able to do for example:
 +<codde>
 +-ssh bebop
 +-screen
 +-salloc -N 1 -p hepd -A condo -t 96:00:00
 +-ssh <nodename>
 +-Work on interactive job for x amount of time...
 +-Disconnect from screen (different than exit, see the documentation)
 +-Logout
 +</code>
 +<code>
 +-Login to the same login node screen was started on
 +-screen -ls
 +-Connect to screen session
 +-Continue where you left off (if they allocation is still active)
 +</code>
 +See below for more details:
 +https://www.gnu.org/software/screen/
 +https://www.hamvocke.com/blog/a-quick-and-easy-guide-to-tmux/
 ====== Using Singularity ====== ====== Using Singularity ======
Line 137: Line 203:
 To run jobs on all LCRC resources using ATLAS analysis base requires Docker/Singularity. To run jobs on all LCRC resources using ATLAS analysis base requires Docker/Singularity.
  Yiming (Ablet) Abulaiti created a tutorial on how to do this. {{:lcrc:analysisbaselcrc.pdf|Read this}}  Yiming (Ablet) Abulaiti created a tutorial on how to do this. {{:lcrc:analysisbaselcrc.pdf|Read this}}
 +Here are the suggested steps for 21.2.51 release.
 +<code>
 +docker pull atlas/analysisbase:21.2.51
 +</code>
 +Then make singularity image:
 +<code bash>
 +docker run -v /var/run/docker.sock:/var/run/docker.sock -v `pwd`:/output --privileged -t --rm singularityware/docker2singularity:v2.3 atlas/analysisbase:21.2.51
 +</code>
 +Currently, the image for AtlasBase 2.2.51 located here:
 +<code>
 +/soft/hep/atlas.cern.ch/repo/containers/images/singularity/atlas_analysisbase_21.2.51-2018-11-04-01795eabe66c.img
 +</code>
 +You can go inside this image as:
 +<code>
 +singularity exec /soft/hep/atlas.cern.ch/repo/containers/images/singularity/atlas_analysisbase_21.2.51-2018-11-04-01795eabe66c.img bash -l
 +</code>
 +====== Using Singularity for cvmfsexec ======
 +One can also setup cvmf on any LCRC nodes as this:
 +<code>
 +source /soft/hep/CVMFSexec/setup.sh
 +</code>
 +Then check:
 +<code>
 +ls /cvmfs/
 +</code>
 +You will see the mounted directory (SL7):
 +<code>
 +atlas-condb.cern.ch/      atlas.cern.ch/  cvmfs-config.cern.ch/  sft-nightlies.cern.ch/  sw.hsf.org/
 +atlas-nightlies.cern.ch/  cms.cern.ch/    projects.cern.ch/      sft.cern.ch/            unpacked.cern.ch/
 +</code>
- --- //[[Sergei&Doug]] 2018/01/04 13:36//+ --- //[[Sergei&Doug&Rui]] 2018/01/04 13:36//
lcrc/introduction.txt ยท Last modified: 2023/06/15 14:05 by rwang
