lcrc:introduction
Differences
lcrc:introduction [2019/01/22 16:44] – [Using Singularity] asc | lcrc:introduction [2022/01/05 15:36] – [Running Batch job on HEP resources] asc | ||
Line 108: | Line 108: | ||
- | srun --pty -p bdwall | + | srun --pty -p bdwall |
Line 131: | Line 131: | ||
To run on non HEP nodes use partition bdwall with Account - ATLAS-HEP-group | To run on non HEP nodes use partition bdwall with Account - ATLAS-HEP-group | ||
+ | == Using interactive jobs == | ||
+ | First, allocate a node: | ||
+ | <code bash> | ||
+ | salloc -N 1 -p hepd -A condo -t 00:30:00 | ||
+ | This allocates it for 30 min, but you can allocate it up to 7 days. | ||
+ | You cam also allocate it on bebob: | ||
+ | salloc -N 1 -p bdwall --account=ATLAS-HEP-group -t 00:30:00 | ||
+ | This does not login you! | ||
+ | Check what node did you allocate | ||
+ | squeue -u user | ||
+ | Now you know the node. Then login to bebob (first!) and then ssh to this node. | ||
+ | Another method is to use | ||
+ | srun --pty -p bdwall | ||
+ | but the job will stop after you logout. | ||
====== Using Singularity ====== | ====== Using Singularity ====== | ||
Line 145: | Line 180: | ||
Then make singularity image: | Then make singularity image: | ||
docker run -v / | docker run -v / | ||
lcrc/introduction.txt · Last modified: 2023/06/15 14:05 by rwang
