phase2:led [2015/07/17 19:16] asc |
phase2:led [2015/08/04 18:35] asc |
Line 10: | Line 10: | ||
wget --no-check-certificate https:// | wget --no-check-certificate https:// | ||
cd pmt_signals_phase2/ | cd pmt_signals_phase2/ | ||
- | python show_trace.py data/ | + | python show_trace.py data/ |
Line 17: | Line 17: | ||
The file names has a letter " | The file names has a letter " | ||
- | - D1 NDF16 + 6xNDF50 | + | - D1 NDF16 + 6xNDF50. Reduction of light by 6*2*16. About 0.3 pc -> x1024 |
- | - D2 NDF16 + 5xNDF50 | + | - D2 NDF16 + 5xNDF50 |
- | - D3 NDF16 + 4xNDF50 | + | - D3 NDF16 + 4xNDF50 |
- | - D4 NDF16 + 3xNDF50 | + | - D4 NDF16 + 3xNDF50 |
- | - D5 NDF16 + 2xNDF50 | + | - D5 NDF16 + 2xNDF50 |
- | - D6 NDF16 + 1xNDF50 | + | - D6 NDF16 + 1xNDF50 |
- | - D7 NDF16 (light reduction by a factor 16) | + | - D7 NDF16 (light reduction by a factor 16) -> x16 |
- | - D8 3xNDF50 | + | - D8 3xNDF50 |
- | - D9 2xNDF50 | + | - D9 2xNDF50 |
- | - D10 1xNDF50 | + | - D10 1xNDF50 |
- | - D11 - no NDF. About 2000 pC | + | - D11 - no NDF. About 2000 pC ->0 |
Figures for 1000 traces are in " | Figures for 1000 traces are in " | ||
Line 33: | Line 33: | ||
- | Blue lines show traces before the noise, and small grey dots after the noise suppression. The green dots show the noise in the LED driver. | + | Blue lines show traces before the noise removal, and small grey dots after the noise suppression. The green dots show the noise in the LED driver. |
