snowmass2013:montecarlo [2013/05/31 00:51] asc |
snowmass2013:montecarlo [2014/04/24 01:51] 127.0.0.1 external edit |
Line 1: | Line 1: | ||
===== Fast Monte Carlo simulation for Snowmass2013 ===== | ===== Fast Monte Carlo simulation for Snowmass2013 ===== | ||
Line 5: | Line 6: | ||
[[http:// | [[http:// | ||
- | * [[https:// | + | * [[https:// |
* 14 TeV pp collision energy. | * 14 TeV pp collision energy. | ||
- | * The Snowmass detector geometry [[http://atlaswww1.hep.anl.gov/ | + | * The Snowmass detector geometry [[http://mc.hep.anl.gov/ |
* PFlow jets with jet area correction. | * PFlow jets with jet area correction. | ||
* Each sample is generated for **< | * Each sample is generated for **< | ||
- | One can view and browser directories with all simulated samples using the [[http://atlaswww1.hep.anl.gov/ | + | One can view and browser directories with all simulated samples using the [[http://mc.hep.anl.gov/ |
- | Background samples are discussed in [[http:// | + | |
Here is a detailed description: | Here is a detailed description: | ||
Line 20: | Line 18: | ||
- **[[snowmass2013: | - **[[snowmass2013: | ||
- | - **[[snowmass2013: | + | - **[[snowmass2013: |
+ | - **[[snowmass2013: | ||
- ttbar+1 gamma | - ttbar+1 gamma | ||
Line 44: | Line 46: | ||
**Warning: most of the models are at the LO level (HERWIG/ | **Warning: most of the models are at the LO level (HERWIG/ | ||
+ | Background samples are discussed in [[http:// | ||
+ | <note important> | ||
===== Truth MC records==== | ===== Truth MC records==== | ||
Line 75: | Line 82: | ||
===== ATLAS-like detector ===== | ===== ATLAS-like detector ===== | ||
- | [[http://atlaswww1.hep.anl.gov/ | + | [[http://mc.hep.anl.gov/ |
===== Other samples ===== | ===== Other samples ===== | ||
Line 91: | Line 98: | ||
