User Tools
Site Tools
snowmass2013:montecarlo
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
snowmass2013:montecarlo [2013/06/28 11:06]
asc
snowmass2013:montecarlo [2014/10/04 13:31]
asc
Line 6: Line 6:
 [[http://atlaswww.hep.anl.gov/asc/arcond/ |Arcond/Condor]]. Details about the Delphes samples for Snowmass are given in [[http://www.snowmass2013.org/tiki-index.php?page=Energy_Frontier_FastSimulation| this wiki]]. [[http://atlaswww.hep.anl.gov/asc/arcond/ |Arcond/Condor]]. Details about the Delphes samples for Snowmass are given in [[http://www.snowmass2013.org/tiki-index.php?page=Energy_Frontier_FastSimulation| this wiki]].
-  * [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes 3.09]]. +  * [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes 3.09]]. Use  Delphes 3 reference [[http://arxiv.org/abs/1307.6346]]
   * 14 TeV pp collision energy.   * 14 TeV pp collision energy.
-  * The Snowmass detector geometry [[http://atlaswww1.hep.anl.gov/asc/snowmass2013/delphes36/?dir=packages | See "updateMay8" input cards]]+  * The Snowmass detector geometry [[http://mc.hep.anl.gov/asc/snowmass2013/delphes36/?dir=packages | See "updateMay8" input cards]]
   * PFlow jets with jet  area correction.   * PFlow jets with jet  area correction.
   * Each sample is generated for **<mu>=0,50,140 pileup** pileup scenarios (soft events are generated with HERWIG++)   * Each sample is generated for **<mu>=0,50,140 pileup** pileup scenarios (soft events are generated with HERWIG++)
-One can view and browser directories with all simulated samples using the [[http://atlaswww1.hep.anl.gov/asc/snowmass2013/delphes36/| ANL Monte Carlo repository]]. +One can view and browser directories with all simulated samples using the [[http://mc.hep.anl.gov/asc/snowmass2013/delphes36/| ANL Monte Carlo repository]].
 Here is a detailed description: Here is a detailed description:
Line 56: Line 56:
 Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: signal, signal+pileup (<mu>=50) and signal+pileup(<mu>=140). Pileup particles are included. Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: signal, signal+pileup (<mu>=50) and signal+pileup(<mu>=140). Pileup particles are included.
-**[[snowmass2013:montecarlo_truth | Repository with truth MC information]]** <fc #FF0000>New</fc>+**[[snowmass2013:montecarlo_truth | Repository with truth MC information]]**
 +**[[http://atlaswww.hep.anl.gov/hepsim/ | HepSim Repository with Monte Carlo predictions for HEP]]** <fc #FF0000>New</fc>
 ===== Help for analyzers==== ===== Help for analyzers====
Line 82: Line 83:
 =====  ATLAS-like detector ===== =====  ATLAS-like detector =====
-[[http://atlaswww1.hep.anl.gov/asc/snowmass2013/atlas/ | Here ]] are the samples for ATLAS-like fast simulation using Delphes 3.03 without pileup removal.+[[http://mc.hep.anl.gov/asc/snowmass2013/atlas/ | Here ]] are the samples for ATLAS-like fast simulation using Delphes 3.03 without pileup removal.
 =====  Other samples ===== =====  Other samples =====
Line 98: Line 99:
  --- //[[[email protected]|Sergei Chekanov]] 2013/03/06 20:47//  --- //[[[email protected]|Sergei Chekanov]] 2013/03/06 20:47//
 --- //[[[email protected]|Alexandre Vaniachine]] 2013/03/06 20:47// --- //[[[email protected]|Alexandre Vaniachine]] 2013/03/06 20:47//
snowmass2013/montecarlo.txt ยท Last modified: 2015/05/12 20:10 by asc
