tier3_admin:tier3cvmfs [2013/08/13 14:48] asc [How to install on SL6.4] |
tier3_admin:tier3cvmfs [2014/05/01 14:40] asc |
Line 54: | Line 54: | ||
yum install compat-expat1 openssl098e libuuid-devel | yum install compat-expat1 openssl098e libuuid-devel | ||
rpm -Uvh http:// | rpm -Uvh http:// | ||
- | yum install cvmfs cvmfs-init-scripts cvmfs-auto-setup | + | yum install cvmfs cvmfs-init-scripts cvmfs-auto-setup |
Line 64: | Line 64: | ||
yum install HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm | yum install HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm | ||
+ | Bob suggested: | ||
+ | cat - >/ | ||
+ | CVMFS_QUOTA_LIMIT=100000 | ||
+ | CVMFS_HTTP_PROXY=" | ||
+ | CVMFS_SERVER_URL=http:// | ||
+ | CVMFS_REPOSITORIES=atlas.cern.ch, | ||
+ | EOF | ||
Line 73: | Line 85: | ||
- | and restart it | + | |
+ | How to test | ||
+ | Run: | ||
+ | and install the needed packages. | ||
+ | export ATLAS_LOCAL_ROOT_BASE=/ | ||
+ | source ${ATLAS_LOCAL_ROOT_BASE}/ | ||
