tilecal:maintenance
Differences
Next revision | Previous revisionNext revisionBoth sides next revision | ||
tilecal:maintenance [2018/02/05 14:24] – created asc | tilecal:maintenance [2018/11/16 12:09] – asc | ||
Line 1: | Line 1: | ||
- | TileCal | + | ====== |
The division is traditionally involved in TileCal Maintenance. Here are a few photos of the 2018 maintenance complain: | The division is traditionally involved in TileCal Maintenance. Here are a few photos of the 2018 maintenance complain: | ||
Line 5: | Line 6: | ||
http:// | http:// | ||
+ | Description: | ||
+ | Mobidick note {{: | ||
+ | ====== Setting up MobiDick computers ====== | ||
+ | http:// | ||
+ | https:// | ||
+ | Software link: | ||
+ | https:// | ||
+ | Computer1: mobi1 (user/pass) | ||
+ | HP ProBook 450 G5. CSI 0356567 | ||
+ | Install from USB CDROM: F10, the go to boot, then go to " | ||
+ | Mobidick server parameters: | ||
+ | 1570 (port) | ||
+ | xterm -hold -e " | ||
+ | Should install: xterm, telnet, expect | ||
+ | The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server | ||
+ | Differences between software 2016 vs 2014 | ||
+ | - DigNoise pannel is different. | ||
+ | 2016 version: Willy version 2.9 2013-02-20 | ||
+ | Mobidick version 5.7 | ||
+ | David Calvet | ||
+ | 2014 version has " | ||
+ | 2016 version has two bars, "High Gain test results" |
tilecal/maintenance.txt · Last modified: 2021/01/14 21:24 by asc
