User Tools
Site Tools
tilecal:maintenance
Differences
Link to this comparison view
Next revision
Previous revision
tilecal:maintenance [2018/08/08 16:40]
asc [Setting up MobiDick computers]
tilecal:maintenance [2021/01/14 21:24]
asc
Line 6: Line 6:
 http://atlaswww.hep.anl.gov/asc/tilecal/maintenance2018/ http://atlaswww.hep.anl.gov/asc/tilecal/maintenance2018/
 +Description: {{:tilecal:mb4.pdf| MobiDick4 wiki}}
 +Mobidick note {{:tilecal:atl-com-tilecal-2014-062.pdf| Mobidick note4}}
 +GIT repository: https://gitlab.cern.ch/atlas-tile-mobidick/Willy/edit
 ====== Setting up MobiDick computers ====== ====== Setting up MobiDick computers ======
Line 12: Line 17:
 https://twiki.cern.ch/twiki/bin/view/Atlas/MobiDick4#Laptop https://twiki.cern.ch/twiki/bin/view/Atlas/MobiDick4#Laptop
 +Software link:
 +https://svnweb.cern.ch/trac/atlasgroups/browser/Detectors/TileCal/MobiDICK
 Computer1: mobi1 (user/pass) Computer1: mobi1 (user/pass)
 +HP ProBook 450 G5. CSI 0356567
 +Install from USB CDROM: F10, the go to boot, then go to "install from file".
 +Mobidick server parameters:
 +<code>
 + 192.168.0.102
 + 1570 (port)
 + xterm -hold -e "expect -c 'spawn telnet -l root 192.168.0.102; expect \"Password:\"; send \"root\r\"; send \"./soft/MobiDICK\r\"; interact'"
 +</code>
 +Should install: xterm, telnet, expect
 +The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server
 +===== Differences between software new vs old (working) version =====
 +===== DigNoise panel is different. =====
 +Willy version 2.9 2013-02-20
 +Mobidick version 5.7
 +David Calvet
 +Working  version has "Pedestal noise result"  with 52  buttons.
 +New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results".
 +===== DigLinerarity =====
 +This panel is missing in the working version
 +===== DigNoiseHV =====
 +Working version has only 52 buttons with "Pedestal noise results"
 +New version has High Gain test results, "Low Gain results" and "Pedestal spread test result"
tilecal/maintenance.txt ยท Last modified: 2021/01/14 21:24 by asc
