User Tools
Site Tools
tilecal:maintenance
Differences
Link to this comparison view
Next revision
Previous revision
tilecal:maintenance [2018/11/16 10:08]
asc
tilecal:maintenance [2021/01/14 21:24]
asc
Line 9: Line 9:
 Mobidick note {{:tilecal:atl-com-tilecal-2014-062.pdf| Mobidick note4}} Mobidick note {{:tilecal:atl-com-tilecal-2014-062.pdf| Mobidick note4}}
 +GIT repository: https://gitlab.cern.ch/atlas-tile-mobidick/Willy/edit
 ====== Setting up MobiDick computers ====== ====== Setting up MobiDick computers ======
Line 39: Line 41:
 The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server
 +===== Differences between software new vs old (working) version =====
 +===== DigNoise panel is different. =====
 +Willy version 2.9 2013-02-20
 +Mobidick version 5.7
 +David Calvet
 +Working  version has "Pedestal noise result"  with 52  buttons.
 +New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results".
 +===== DigLinerarity =====
 +This panel is missing in the working version
 +===== DigNoiseHV =====
 +Working version has only 52 buttons with "Pedestal noise results"
 +New version has High Gain test results, "Low Gain results" and "Pedestal spread test result"
tilecal/maintenance.txt ยท Last modified: 2021/01/14 21:24 by asc
