User Tools
Site Tools
tilecal:maintenance
Differences
Link to this comparison view
Next revision
Previous revision
tilecal:maintenance [2018/11/16 12:11]
asc
tilecal:maintenance [2021/01/14 21:24]
asc
Line 9: Line 9:
 Mobidick note {{:tilecal:atl-com-tilecal-2014-062.pdf| Mobidick note4}} Mobidick note {{:tilecal:atl-com-tilecal-2014-062.pdf| Mobidick note4}}
 +GIT repository: https://gitlab.cern.ch/atlas-tile-mobidick/Willy/edit
 ====== Setting up MobiDick computers ====== ====== Setting up MobiDick computers ======
Line 52: Line 54:
 Working  version has "Pedestal noise result"  with 52  buttons. Working  version has "Pedestal noise result"  with 52  buttons.
 New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results". New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results".
 +===== DigLinerarity =====
 +This panel is missing in the working version
 +===== DigNoiseHV =====
 +Working version has only 52 buttons with "Pedestal noise results"
 +New version has High Gain test results, "Low Gain results" and "Pedestal spread test result"
tilecal/maintenance.txt ยท Last modified: 2021/01/14 21:24 by asc
