User Tools
Site Tools
vlhc:hcal
Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
vlhc:hcal [2014/11/26 19:28]
asc
vlhc:hcal [2014/12/03 15:41]
asc
Line 2: Line 2:
 ====== FCC HCAL using a fast simulation ====== ====== FCC HCAL using a fast simulation ======
-[[http://atlaswww.hep.anl.gov/hepsim/HepSim | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]]. +[[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]].
 +To simplify the setup, we have prepared a package that includes [[http://cp3.irmp.ucl.ac.be/downloads/Delphes-3.1.2.tar.gz | Delphes-3.1.2]], [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC 1.5]] and HS-TOOLs.
 Follow these steps: Follow these steps:
Line 151: Line 153:
 ===== How to run ===== ===== How to run =====
-We need to bring truth-level data from [[http://atlaswww.hep.anl.gov/hepsim/| HepSim]] and put them somewhere. For this example, +We need to bring truth-level data from [[http://atlaswww.hep.anl.gov/hepsim/| HepSim]] and put them somewhere.
-we will use [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=57 | TTBar sample]] generated with pT>2.5 TeV and look at the jet mass.+We will use [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=57 | TTBar sample]] generated with pT>2.5 TeV and look at the jet mass.
 Go to "analysis" directory and copy a few truth-level files: Go to "analysis" directory and copy a few truth-level files:
 <code bash> <code bash>
 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_pt2500_mg5  data 2 10 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_pt2500_mg5  data 2 10
 </code> </code>
-This copies 10 files in 2 threads and put them to the directory "data". Now we are ready to run over these files.+This copies 10 files in 2 threads and put them to the directory "data". Now we are ready to run over these 10 files.
 Let us make 2 runs: One run  will use the first geometry layout, and the second run will use the 2nd input card. Let us make 2 runs: One run  will use the first geometry layout, and the second run will use the 2nd input card.
Line 174: Line 176:
 To make plot, run {{:vlhc:mass.py|}} script. This will show 2 jets masses for boosted top  for different HCAL segmentation. To make plot, run {{:vlhc:mass.py|}} script. This will show 2 jets masses for boosted top  for different HCAL segmentation.
-{{:vlhc:mass_towers.png}}+
 +{{:vlhc:mass_towers.eps.png?400|}}
 Note: the eflow option has much better resolution for jet masses. Note: the eflow option has much better resolution for jet masses.
-===== Using particle flows =====+===== Using particle flows (eFlow) =====
Line 194: Line 199:
 +Now let's try to run using "eFlow" cards:
 +{{:vlhc:mass_eflow.eps.png?400|}}
 +{{:vlhc:tau32_eflow.eps.png?400|}}
 ===== Next steps ===== ===== Next steps =====
vlhc/hcal.txt · Last modified: 2015/10/17 15:33 by asc
