vlhc:hcal [2014/12/02 17:17] asc [How to run] |
vlhc:hcal [2014/12/03 15:41] asc |
Line 3: | Line 3: | ||
[[http:// | [[http:// | ||
+ | To simplify the setup, we have prepared a package that includes [[http:// | ||
Follow these steps: | Follow these steps: | ||
Line 151: | Line 153: | ||
===== How to run ===== | ===== How to run ===== | ||
- | We need to bring truth-level data from [[http:// | + | We need to bring truth-level data from [[http:// |
- | we will use [[https:// | + | We will use [[https:// |
Go to " | Go to " | ||
hs-get http:// | hs-get http:// | ||
- | This copies 10 files in 2 threads and put them to the directory " | + | This copies 10 files in 2 threads and put them to the directory " |
Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | ||
Line 176: | Line 178: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 198: | Line 199: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
