vlhc:hcal [2014/12/02 17:17] asc [How to run] |
vlhc:hcal [2015/01/16 15:53] asc |
Line 1: | Line 1: | ||
[[http:// | [[http:// | ||
- | Follow these steps: | + | To simplify the setup, we have prepared a package that includes [[https:// |
Line 25: | Line 25: | ||
- | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. | + | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below. |
===== ATLAS-like geometry ===== | ===== ATLAS-like geometry ===== | ||
Line 151: | Line 151: | ||
===== How to run ===== | ===== How to run ===== | ||
- | We need to bring truth-level data from [[http:// | + | We need to bring truth-level data from [[http:// |
- | we will use [[https:// | + | We will use [[https:// |
Go to " | Go to " | ||
hs-get http:// | hs-get http:// | ||
- | This copies 10 files in 2 threads and put them to the directory " | + | This copies 10 files in 2 threads and put them to the directory " |
Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | ||
Line 176: | Line 176: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 198: | Line 197: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
