vlhc:hcal [2014/12/03 15:37] asc [How to run] |
vlhc:hcal [2014/12/03 15:40] asc |
Line 3: | Line 3: | ||
[[http:// | [[http:// | ||
+ | To simplify the setup, we have prepared a package that includes [[http:// | ||
Follow these steps: | Follow these steps: | ||
Line 178: | Line 180: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 200: | Line 199: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
