vlhc:hcal [2014/12/03 15:38] asc [How to run] |
vlhc:hcal [2014/12/03 15:38] asc [Using particle flows] |
Line 178: | Line 178: | ||
- | Now let's try to run using " | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 202: | Line 197: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
