vlhc:hcal
Differences
vlhc:hcal [2014/12/03 15:38] – [Using particle flows] asc | vlhc:hcal [2014/12/03 15:42] – [FCC HCAL using a fast simulation] asc | ||
Line 3: | Line 3: | ||
[[http:// | [[http:// | ||
- | Follow these steps: | + | To simplify the setup, we have prepared a package that includes [[https:// |
Line 25: | Line 25: | ||
- | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. | + | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below. |
===== ATLAS-like geometry ===== | ===== ATLAS-like geometry ===== | ||
Line 181: | Line 181: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
vlhc/hcal.txt · Last modified: 2015/10/17 15:33 by asc
