vlhc:intro [2014/10/27 04:35] asc [Monte CArlo simulation files] |
vlhc:intro [2015/08/19 18:21] asc |
Line 3: | Line 3: | ||
[[https:// | [[https:// | ||
+ | [[vlhc:hcal | HCAL studies for VLHC]] | ||
- | ====== Monte CArlo simulation files ====== | ||
- | Monte Carlo simulation files with 100 TeV collision events can be downloaded from [[http:// | + | ====== Using SLIC for 100 TeV pp====== |
+ | Some reconstructed data are in [[http:// | ||
+ | The instruction how to Run SLIC are attached (created by Jan Strube) | ||
+ | For those who have an account at CERN, here are some instructions to go | ||
+ | through the different steps of the simulation and reconstruction. We are | ||
+ | using Whizard https:// | ||
+ | - Setup the environment: | ||
+ | - Download a physics file: wget | ||
+ | ftp:// | ||
+ | .stdhep | ||
+ | - Download a detector: | ||
+ | -- wget http:// | ||
+ | -- mkdir sidloi3 | ||
+ | -- cd sidloi3 | ||
+ | -- unzip ../ | ||
+ | - Convert the compact format to other necessary formats | ||
+ | -- GeomConverter -o lcdd compact.xml sidloi3.lcdd | ||
+ | -- GeomConverter -o heprep compact.xml sidloi3.heprep | ||
+ | -- GeomConverter -o pandora compact.xml sidloi3.pandora | ||
+ | -- cd .. | ||
+ | - Run the simulation on 10 events (The crossing angle of the beams is | ||
+ | flexible in our simulation. The physics is from head-on collisions. The | ||
+ | events need to be boosted appropriately such that the outgoing beams go | ||
+ | through the right beam pipe): | ||
+ | pythiaZPolemumu.stdhep -g sidloi3/ | ||
+ | input.slcio | ||
+ | - Run the digitization and tracking: | ||
+ | lcsim -D inputFile=input.slcio -D | ||
+ | trackingStrategies=/ | ||
+ | Strategies.xml -D outputFile=tracking.slcio | ||
+ | - Run the particle flow reconstruction: | ||
+ | PandoraFrontend -g sidloi3/ | ||
+ | ====== Truth-level Monte Carlo files ====== | ||
+ | Monte Carlo simulation files with 100 TeV collision events can be downloaded from the [[http:// | ||
