vlhc:intro [2014/10/27 04:36] asc [Monte CArlo simulation files] |
vlhc:intro [2015/08/19 18:25] asc |
Line 3: | Line 3: | ||
[[https:// | [[https:// | ||
+ | ====== Using SLIC for 100 TeV pp====== | ||
- | ====== Monte CArlo simulation files ====== | + | Some reconstructed 100 TeV data using SLIC are in [[http:// |
- | Monte Carlo simulation files with 100 TeV collision events can be downloaded from [[http:// | + | The instruction how to Run SLIC are attached (created by Jan Strube). The instruction works for e+e- collisions |
+ | generated by Whizard [[https:// | ||
+ | <code bash> | ||
+ | # Setup the environment: | ||
+ | source / | ||
+ | # Download a physics file: | ||
+ | wget ftp:// | ||
+ | # Download a detector: | ||
+ | wget http:// | ||
+ | mkdir sidloi3 | ||
+ | cd sidloi3 | ||
+ | unzip ../ | ||
+ | # Convert the compact format to other necessary formats | ||
+ | GeomConverter -o lcdd compact.xml sidloi3.lcdd | ||
+ | GeomConverter -o heprep compact.xml sidloi3.heprep | ||
+ | GeomConverter -o pandora compact.xml sidloi3.pandora | ||
+ | cd .. | ||
+ | # Run the simulation on 10 events (The crossing angle of the beams is | ||
+ | # flexible in our simulation. The physics is from head-on collisions. The | ||
+ | # events need to be boosted appropriately such that the outgoing beams go | ||
+ | # through the right beam pipe): | ||
+ | pythiaZPolemumu.stdhep -g sidloi3/ | ||
+ | # Run the digitization and tracking: | ||
+ | lcsim -D inputFile=input.slcio -D trackingStrategies=/ | ||
+ | # Run the particle flow reconstruction: | ||
+ | PandoraFrontend -g sidloi3/ | ||
+ | ====== Truth-level Monte Carlo files ====== | ||
+ | Monte Carlo simulation files with 100 TeV collision events can be downloaded from the [[http:// | ||
+ | ====== HCAL studies ====== | ||
+ | [[vlhc:hcal | HCAL studies for VLHC]] | ||
