User Tools
Site Tools
community:hepsim:usage_full
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
community:hepsim:usage_full [2016/04/29 00:06] – [LCIO event structure] asccommunity:hepsim:usage_full [2017/09/30 14:35] (current) asc
Line 1: Line 1:
 +<note important>This manual is outdated. Please use
 +http://atlaswww.hep.anl.gov/hepsim/doc/doku.php
 +</note>
 [[community:hepsim:|<< back to HepSim manual]] [[community:hepsim:|<< back to HepSim manual]]
 ====== Full detector simulations  ====== ====== Full detector simulations  ======
-Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and+Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and
 use these files for the "slic" Geant4-based program. use these files for the "slic" Geant4-based program.
 To process SLCIO files, you will need [[http://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]]  program. To process SLCIO files, you will need [[http://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]]  program.
 The files with full simulations are located under the "rfullNNN" tags ("NNN" is a number) The files with full simulations are located under the "rfullNNN" tags ("NNN" is a number)
-Here how you can find all samples that have "rfull" tag for download. Click here: [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull]]. If you need to find all  files+Here how you can find all samples that have "rfull" tag for download. Click here: [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull]].
 +The description of the detector tags is given in [[community:hepsim:usage_detectors|Detector description]].
 + If you need to find all  files
 for a give tag, say rfull005, use this command: for a give tag, say rfull005, use this command:
Line 53: Line 60:
   * Visualisation of reconstructed events using Wired4 display   * Visualisation of reconstructed events using Wired4 display
-You can find more details in [[asc:jas4pp|Jas4pp manual]]. The example showing how to run over SLCIO files using [[https://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] are located in the "examples/slic" directory of the Jas4pp package. +You can find more details in [[asc:jas4pp|Jas4pp manual]]. The examples showing how to run over SLCIO files using [[https://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] are located in the "examples/slic" directory of the Jas4pp package.
community/hepsim/usage_full.1461888377.txt.gz · Last modified: 2016/04/29 00:06 by asc
