community:hepsim:usage_full
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
community:hepsim:usage_full [2016/04/29 00:07] – asc | community:hepsim:usage_full [2017/09/30 14:35] (current) – asc | ||
Line 1: | Line 1: | ||
+ | <note important> | ||
+ | http:// | ||
====== Full detector simulations | ====== Full detector simulations | ||
- | Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | + | Currently, the Geant4-based |
use these files for the " | use these files for the " | ||
To process SLCIO files, you will need [[http:// | To process SLCIO files, you will need [[http:// | ||
The files with full simulations are located under the " | The files with full simulations are located under the " | ||
- | Here how you can find all samples that have " | + | Here how you can find all samples that have " |
+ | The description of the detector tags is given in [[community: | ||
+ | If you need to find all files | ||
for a give tag, say rfull005, use this command: | for a give tag, say rfull005, use this command: | ||
community/hepsim/usage_full.1461888478.txt.gz · Last modified: 2016/04/29 00:07 by asc
