asc:jas4pp [2021/02/16 23:33] asc [Reading ROOT files] |
asc:jas4pp [2023/05/24 02:01] asc |
Line 27: | Line 27: | ||
a data-analysis environment for detector and physics studies of future circular colliders. Jas4PP is a merge of several open-source Java projects, such as | a data-analysis environment for detector and physics studies of future circular colliders. Jas4PP is a merge of several open-source Java projects, such as | ||
- | * Many file formats used in HEP, including | + | * Many file formats used in HEP, including |
- | * [[https:// | + | * [[https:// |
* [[https:// | * [[https:// | ||
Line 43: | Line 43: | ||
+ | ====== Installation | ||
The installation does not have external dependencies. | The installation does not have external dependencies. | ||
One can find Oracle JDK or JRE versions from the [[http:// | One can find Oracle JDK or JRE versions from the [[http:// | ||
Line 48: | Line 49: | ||
- | <note tip>Although Jas4pp works on JDK8, we strongly recommend to use JDK9 (or OpenJDK9) and above. This will significantly increase the speed for numeric computations. | + | <note tip>We strongly recommend to use JDK18 (or OpenJDK18) and above. This will significantly increase the speed for numeric computations. |
You can download the Jas4pp program using the [[http:// | You can download the Jas4pp program using the [[http:// | ||
- | Then run these commands to install the package using Linux/Mac with the " | + | |
+ | You can use Jas4pp installer program (jas4pp-[VERSION]-installer.jar). | ||
+ | It asks several questions and creates an icon on a desktop. It is recommended to install the program in " | ||
+ | Alternatively, | ||
+ | Run these commands to install the package using Linux/Mac with the " | ||
Line 62: | Line 68: | ||
bash> jaspp | bash> jaspp | ||
- | The last command starts Jas4PP GUI. | + | The last command starts Jas4PP GUI: |
+ | ====== How to run ====== | ||
+ | Use this GUI to explore examples with data visualisation shown in the main window: | ||
+ | [JAS4PP examples]-[Python examples] and then [F2] (or use the mouse menu) to execute: | ||
If you run Jython/ | If you run Jython/ | ||
Line 303: | Line 320: | ||
- | The script that calls these browsers | + | The last image shows the complete class structure of the ROOT file. |
+ | Thses scripts | ||
Line 315: | Line 333: | ||
This functionality is unchanged compared to [[http:// | This functionality is unchanged compared to [[http:// | ||
- | }===== Analysis of Delphes ROOT files ===== | + | ===== Analysis of Delphes ROOT files ===== |
Jas4pp can be used for analysis of complex ROOT trees from fast simulations created by the [[https:// | Jas4pp can be used for analysis of complex ROOT trees from fast simulations created by the [[https:// | ||
Line 331: | Line 349: | ||
rootio.Browser(" | rootio.Browser(" | ||
+ | The browser | ||
The process the tree " | The process the tree " | ||
Here is a simple code to show a histogram with particle ID: | Here is a simple code to show a histogram with particle ID: | ||
<hidden Click here to show a Python code to read Delphes files> | <hidden Click here to show a Python code to read Delphes files> | ||
<code python> | <code python> | ||
Line 347: | Line 365: | ||
reader = RootFileReader(xf) | reader = RootFileReader(xf) | ||
tree = reader.get(" | tree = reader.get(" | ||
- | maxevents=tree.getEntries() | ||
branches=tree.getBranches() | branches=tree.getBranches() | ||
print "Nr of events=", | print "Nr of events=", | ||
Line 368: | Line 384: | ||
print PID.getName(), | print PID.getName(), | ||
- | ### plot particle ID ## | ||
from jhplot import * | from jhplot import * | ||
- | h1 = H1D(" | + | h1 = H1D(" |
pid=leaves.get(0) # get values with PID for all events | pid=leaves.get(0) # get values with PID for all events | ||
Line 384: | Line 399: | ||
- | Here is an example that use high-level classes | + | Note this code only works for integer values since we did not specify which value needs to be extracted. |
- | <code python> | + | If you need to extract double, float or boolean values, use the [[https:// |
- | import rootio | + | getFloat, getDouble, getInt, and getBool. |
- | rootio.Browser(" | + | Here is an example that uses high-level classes |
- | </code> | + | |
- | The process the tree "Delphes" | + | |
- | Here is a simple code to show a histogram with particle ID: | + | |
Line 400: | Line 411: | ||
from rootio import * | from rootio import * | ||
- | xf=" | + | reader |
- | + | tree = reader.get(" | |
- | # examine file before doing anything | + | |
- | # import rootio | + | |
- | # rootio.Browser(xf) | + | |
- | reader = RootFileReader(xf) | + | |
- | tree = reader.get(" | + | |
- | maxevents=tree.getEntries() | + | |
print "Nr of branches=", | print "Nr of branches=", | ||
print " | print " | ||
- | for l in xrange( branches.size() | + | for l in xrange( branches.size() ): |
- | # get generator particles | + | particles=tree.getBranch(" |
- | particles=tree.getBranch(" | + | ptEvents=Delphes.getFloat(particles," |
- | + | etaEvents=Delphes.getFloat(particles," | |
- | # get all PT and Eta in events | + | |
- | ptEvents=Delphes.getFloat(particles," | + | |
- | etaEvents=Delphes.getFloat(particles," | + | |
Line 427: | Line 428: | ||
h2 = H1D(" | h2 = H1D(" | ||
for i in xrange(tree.getEntries()): | for i in xrange(tree.getEntries()): | ||
- | | + | pt,eta=ptEvents[i],etaEvents[i] |
- | eta=etaEvents[i] | + | |
for j in xrange(len(pt)): | for j in xrange(len(pt)): | ||
Line 447: | Line 447: | ||
<note warning> | <note warning> | ||
+ | Jas4pp can visualize histograms created by Fortran or C++ code (but without using ROOT). For this, use a light stand-alone library called CFBook (See [[https:// | ||
+ | <hidden Click to show the Python code> | ||
+ | <code python> | ||
+ | from jhplot | ||
+ | from jhplot.io import * | ||
+ | hb = CFBook() | ||
+ | hb.read(" | ||
+ | print hb.listAll() | ||
+ | print hb.getKeysH1D() # list keys | ||
+ | h1=hb.getH1D(1) | ||
+ | c1=HPlot(" | ||
+ | c1.setGTitle(" | ||
+ | c1.visible(1) | ||
+ | c1.setAutoRange() | ||
+ | c1.draw(h1) | ||
====== Reading LCIO files ====== | ====== Reading LCIO files ====== | ||
Line 780: | Line 802: | ||
* N.Nikiforou | * N.Nikiforou | ||
* G.Gavalian (JLab) | * G.Gavalian (JLab) | ||
+ | * Khushi Taori (ANL SULI 2021 student). ROOT6 support | ||
