asc:promc:examples [2014/10/14 18:50] asc |
asc:promc:examples [2015/03/20 01:16] asc [Default data layouts] |
Line 6: | Line 6: | ||
(written by S.Chekanov, ANL) | (written by S.Chekanov, ANL) | ||
- | ProMC binary | + | ProMC files are compact and self-describing |
to ProMC files. More information is in the [[asc: | to ProMC files. More information is in the [[asc: | ||
Line 33: | Line 33: | ||
Look at the Python examples discussed bellow how to use a random access via the network. | Look at the Python examples discussed bellow how to use a random access via the network. | ||
+ | Note that the browser can open ProMC files of any size, since it loads only a fraction of data. This is especially useful compared to limitations | ||
+ | of some formats that cannot be viewed in text editors if their sizes are too large. | ||
Line 55: | Line 58: | ||
After the installation, | After the installation, | ||
$PROMC/ | $PROMC/ | ||
- | If you already know that your files includes | + | If you already know that your file include information from a typical |
- | that reads ProMC (and links libpromc.a library). | + | that reads a ProMC file. The makefile |
- | If you know that stored data are NLO, looks at the reader in: | + | If you know that stored data are from a NLO program, looks at: |
- | that links libpronlo.a library | + | that links the "libpronlo.a" |
- | ProMC files are self-describing, | + | ProMC files are self-describing, |
You can generate | You can generate | ||
if you happen to have a ProMC file but do not know how the data are organized inside the file. You need to install [[asc: | if you happen to have a ProMC file but do not know how the data are organized inside the file. You need to install [[asc: | ||
Line 209: | Line 212: | ||
The example given in the directory " | The example given in the directory " | ||
- | ===== Benchmark summary | ||
- | Here is a comparison of file sizes for the same event records written by " | ||
- | ^ File format | ||
- | | ASCII TXT file (" | ||
- | | ROOT tree (Double32_t) | ||
- | As one can see, the ProMC files are 40% more compact than the equivalent ROOT files and 23% more compact than gzipped ASCII TXT (" | ||
Line 253: | Line 242: | ||
- | An example program which fills ProMC file record is given here | + | An example program which fills ProMC file record is given in |
- | [[http://atlaswww.hep.anl.gov/asc/WebSVN/ | + | [[https://github.com/Argonne-National-Laboratory/ProMC/blob/master/examples/pythia/|Pythia8 to ProMC example]] |
Line 475: | Line 464: | ||
- | - [[http://atlaswww.hep.anl.gov/asc/WebSVN/filedetails.php? | + | - [[https://github.com/ |
- | - [[http://atlaswww.hep.anl.gov/asc/WebSVN/filedetails.php? | + | - [[https://github.com/Argonne-National-Laboratory/ProMC/ |
- [[http:// | - [[http:// | ||
+ | - [[https:// | ||
More complex layout files (for example, foe Delphes fast simulation) can be found | More complex layout files (for example, foe Delphes fast simulation) can be found | ||
inside the directory " | inside the directory " |
