User Tools
Site Tools
asc:promc:installation
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
asc:promc:installation [2015/01/14 23:34]
asc [Installation from the source (Mac OS)]
asc:promc:installation [2015/01/15 22:24]
Line 54: Line 54:
 Then get the current ProMC release from [[https://atlaswww.hep.anl.gov/asc/promc/download/|Download page]]. Then get the current ProMC release from [[https://atlaswww.hep.anl.gov/asc/promc/download/|Download page]].
-Below we show how to download and compile the most recent ProMC package (i.e. ProMC-1.3.tgz):+Below we show how to download and compile the most recent ProMC package (i.e. ProMC-1.5.tgz):
 <code bash> <code bash>
Line 89: Line 89:
 ./install.sh  /usr/local  /user/local/HEPMC ./install.sh  /usr/local  /user/local/HEPMC
-source [promc_dir]/setup.sh make it available+source [promc_dir]/setup.sh set PROMC env variable
 </code>  </code>
Line 97: Line 97:
 echo $PROMC echo $PROMC
 </code> </code>
-returns the installation ProMC  directory. Now you can remove the original build directory "ProMC"Test the instillation by writing and reading random numbers :+returns the installation ProMC  directory. Now you can remove the original build directory "ProMC"To test the installation, go to the example directory and run the example that write and reads random numbers in a file:
Line 108: Line 108:
 ====== Installation from the source (Mac OS) ====== ====== Installation from the source (Mac OS) ======
-For MacOS (Darwin), first install these libraries:+For MacOS (Darwin), first install these libraries: pkgconfig, wget, gcc. You can can use Xcode and Fink and to install such dev libraries.
 +If you do not use "Fink", you should use XCode and MacPort:
   * Xcode and the Xcode Command Line Tools. Then agree to Xcode license in Terminal: "**sudo xcodebuild -license**"   * Xcode and the Xcode Command Line Tools. Then agree to Xcode license in Terminal: "**sudo xcodebuild -license**"
-  * MacPorts for your version of OS X: 10.10 and then "**sudo port install pkgconfig autocong wget**"+  * MacPorts for your version of OS X: 10.10 and then "**sudo port install pkgconfig wget**"
-We assume you are using "bash" terminal. Then do this (as before):+The current installation was tested with Xcode/Fink  or using  Xcode/MacPorts.
 +Next we  assume that you are using the "bash" terminal. Then repeat the same steps as for Linux:
 +bash
 wget http://atlaswww.hep.anl.gov/asc/promc/download/current.php -O ProMC.tgz wget http://atlaswww.hep.anl.gov/asc/promc/download/current.php -O ProMC.tgz
 tar -zvxf ProMC.tgz tar -zvxf ProMC.tgz
 cd ProMC cd ProMC
 ./build.sh                   # build all source files ./build.sh                   # build all source files
-./install.sh [promc_dir]     # install into some directory +./install.sh [promc_dir]     # install into [promc_dir] directory
-source [promc_dir]/setup.sh make it available+source [promc_dir]/setup.sh set PROMC env variable.
 </code> </code>
-Test  the instillation by writing and reading random numbers :+To test the installation, go to the example directory and run the example that writes and reads random numbers in/from a file:
Line 133: Line 136:
 </code> </code>
-You can download compiled ProMC library (MacOS 10.10.1) from [[http://atlaswww.hep.anl.gov/asc/promc/download/promc1.5_macOS_10.10.1.tgz]]. +You can download compiled ProMC library (MacOS 10.10.1) from [[http://atlaswww.hep.anl.gov/asc/promc/download/promc1.5_macOS_10.10.1.tgz]].
 +Thanks to Larry Nodulman for verifying this installation.
Line 193: Line 196:
-===== Installation for IBM BlueGene/Q =====+===== Installation on IBM BlueGene/Q =====
 //(contributed by Ed May and William Scullin)// //(contributed by Ed May and William Scullin)//
asc/promc/installation.txt · Last modified: 2015/03/20 01:08 by asc
