asc:promc:installation [2015/01/15 21:42] asc [Installation from the source (Mac OS)] |
asc:promc:installation [2015/03/20 01:08] asc |
Line 54: | Line 54: | ||
Then get the current ProMC release from [[https:// | Then get the current ProMC release from [[https:// | ||
- | Below we show how to download and compile the most recent ProMC package (i.e. ProMC-1.3.tgz): | + | You can also use [[https:// |
+ | Below we show how to download and compile the most recent ProMC package (i.e. ProMC-1.5.tgz): | ||
Line 89: | Line 90: | ||
- | source [promc_dir]/ | + | source [promc_dir]/ |
Line 97: | Line 98: | ||
echo $PROMC | echo $PROMC | ||
- | returns the installation ProMC directory. Now you can remove the original build directory " | + | returns the installation ProMC directory. Now you can remove the original build directory " |
Line 108: | Line 109: | ||
====== Installation from the source (Mac OS) ====== | ====== Installation from the source (Mac OS) ====== | ||
- | For MacOS (Darwin), first install these libraries: pkgconfig, wget, gcc etc. You can can use "Fink" | + | For MacOS (Darwin), first install these libraries: pkgconfig, wget, gcc. You can can use Xcode and Fink and to install such dev libraries. |
- | Or you can use XCode and MacPort: | + | If you do not use " |
* Xcode and the Xcode Command Line Tools. Then agree to Xcode license in Terminal: " | * Xcode and the Xcode Command Line Tools. Then agree to Xcode license in Terminal: " | ||
* MacPorts for your version of OS X: 10.10 and then " | * MacPorts for your version of OS X: 10.10 and then " | ||
- | Next we assume that you are using the " | + | The current installation was tested with Xcode/ |
+ | Next we assume that you are using the " | ||
+ | bash | ||
tar -zvxf ProMC.tgz | tar -zvxf ProMC.tgz | ||
cd ProMC | cd ProMC | ||
- | Test | + | To test the installation, |
Line 134: | Line 137: | ||
- | You can download compiled ProMC library (MacOS 10.10.1) from [[http:// | + | You can download |
- | + | Thanks | |
- | Thanks | + | |
Line 195: | Line 197: | ||
- | ===== Installation | + | ===== Installation |
