asc:promc:introduction [2014/05/21 01:07] asc [Using C++ to write/read ProMC] |
asc:promc:introduction [2017/03/22 11:25] asc |
Line 82: | Line 82: | ||
Line 130: | Line 121: | ||
There are a few files used to create and read ProMC files: | There are a few files used to create and read ProMC files: | ||
- | * The description message is [[http://atlaswww.hep.anl.gov/asc/WebSVN/ | + | * The description message is [[https://github.com/Argonne-National-Laboratory/ProMC/ |
- | * The header of the file record is [[http://atlaswww.hep.anl.gov/asc/WebSVN/ | + | * The header of the file record is [[https://github.com/Argonne-National-Laboratory/ProMC/ |
- | * The MC event record (repeatable) [[http://atlaswww.hep.anl.gov/asc/WebSVN/filedetails.php? | + | * The MC event record (repeatable) [[https://github.com/Argonne-National-Laboratory/ProMC/ |
- | * The statistics of the generated events is stored in [[http://atlaswww.hep.anl.gov/asc/WebSVN/ | + | * The statistics of the generated events is stored in [[https://github.com/Argonne-National-Laboratory/ProMC/ |
These are the files that are shipped with the default installation and suitable to keep truth MC information. A more complicated data layouts are given in examples/ | These are the files that are shipped with the default installation and suitable to keep truth MC information. A more complicated data layouts are given in examples/ | ||
Line 165: | Line 156: | ||
Line 212: | Line 208: | ||
- | wget http://mc.hep.anl.gov/ | + | wget http://atlaswww.hep.anl.gov/ |
- | unzip -l MadGraph5Pythia_wjets_mu0.promc | + | unzip -l Pythia8.promc |
- | You can uncompress events into files as " | + | You can uncompress events into files as " |
- | unzip -p MadGraph5Pythia_wjets_mu0.promc 100 > 100.event | + | unzip -p Pythia8.promc 100 > 100.event |
- | unzip -p MadGraph5Pythia_wjets_mu0.promc | + | unzip -p Pythia8.promc ProMC.proto |
This example | This example | ||
Line 228: | Line 224: | ||
unzip -p <ProMC file> | unzip -p <ProMC file> | ||
- | unzip -p <ProMC file> | + | unzip -p <ProMC file> |
- | In these examples, we send the contents of the files " | + | In these examples, we send the contents of the files " |
Line 242: | Line 238: | ||
+ | | java -cp .: | ||
Note that the conversion tools (hepmc2promc, | Note that the conversion tools (hepmc2promc, | ||
Line 279: | Line 279: | ||
An example which shows how to read such PROMC file can be found in " | An example which shows how to read such PROMC file can be found in " | ||
- | Starting from Pythi8 version 8180, ProMC is included into the Pythia8 package. See the example " | + | Starting from Pythi8 version 8180, ProMC is included into the Pythia8 package. See the example " |
- | + | * Here we open ProMC for writing: | |
- | There are two possible options to initialize ProMC: | + | |
- | Here we open ProMC for writing: | + | |
<code cpp> | <code cpp> | ||
Line 290: | Line 287: | ||
- | Each event will be written to the disk (after each " | + | Event will be written to the disk after each " |
+ | After this limit, ProMC will attempt to close the file. | ||
Use this option to write large events, but limiting their number to 65k. | Use this option to write large events, but limiting their number to 65k. | ||
- | Another option is to write events "in memory": | + | * Another option is to write events "in memory": |
Line 299: | Line 297: | ||
- | With this option, all events are accumulated inside memory, and then they are written to the disk after " | + | With this option, all events are accumulated inside |
Use this option to write " | Use this option to write " | ||
There is no limit on how many events are stored, since this option uses " | There is no limit on how many events are stored, since this option uses " | ||
- | To read events, use this option: | + | * To read events, use this option: |
Line 476: | Line 474: | ||
The Java API of the part which access info inside the ProMC files is [[http:// | The Java API of the part which access info inside the ProMC files is [[http:// | ||
+ | * [[http:// | ||
Line 482: | Line 481: | ||
- | If you create a different data layout, you can generate | + | If you create a different data layout, you can generate |
Line 525: | Line 524: | ||
* Use [[http:// | * Use [[http:// | ||
- | * Use [[http:// | + | * Use [[http:// |
Line 655: | Line 654: | ||
ProMC is a rewrite of an older package (CBook) | ProMC is a rewrite of an older package (CBook) | ||
for the community supported [[http:// | for the community supported [[http:// | ||
- | Currently, this program has the name [[http:// | + | Currently, this program has the name [[http:// |
Line 706: | Line 705: | ||
* S.V.Chekanov, | * S.V.Chekanov, | ||
- | * S.V. Chekanov, E.May, K. Strand, P. Van Gemmeren, ProMC: Input-output data format for HEP applications using varint encoding, ANL-HEP-PR-13-41 [[http:// | + | * S.V. Chekanov, E.May, K. Strand, P. Van Gemmeren, ProMC: Input-output data format for HEP applications using varint encoding, ANL-HEP-PR-13-41 [[http:// |
- | + | Bibtex entry: | |
+ | @article{Chekanov20142629, | ||
+ | title = " | ||
+ | journal = " | ||
+ | volume = " | ||
+ | number = " | ||
+ | pages = "2629 - 2635", | ||
+ | year = " | ||
+ | note = "", | ||
+ | issn = " | ||
+ | doi = " | ||
+ | url = " | ||
+ | author = "S.V. Chekanov and E. May and K. Strand and P. Van Gemmeren", | ||
+ | keywords = " | ||
+ | abstract = " | ||
