asc:promc:introduction [2015/05/10 21:06] asc |
asc:promc:introduction [2017/03/22 11:27] asc [Available ProMC commands] |
Line 82: | Line 82: | ||
Line 165: | Line 156: | ||
Line 242: | Line 239: | ||
+ | | java -cp .: | ||
Note that the conversion tools (hepmc2promc, | Note that the conversion tools (hepmc2promc, | ||
Line 474: | Line 475: | ||
The Java API of the part which access info inside the ProMC files is [[http:// | The Java API of the part which access info inside the ProMC files is [[http:// | ||
+ | * [[http:// | ||
Line 480: | Line 482: | ||
- | If you create a different data layout, you can generate | + | If you create a different data layout, you can generate |
