asc:promc:introduction [2015/07/07 21:09] asc [Using Java and Java API] |
asc:promc:introduction [2017/03/22 11:29] asc [Available ProMC commands] |
Line 82: | Line 82: | ||
Line 163: | Line 154: | ||
Line 242: | Line 230: | ||
- | | promc2root | + | | promc2stdhep |
| java -cp .: | | java -cp .: | ||
Line 483: | Line 474: | ||
- | If you create a different data layout, you can generate | + | If you create a different data layout, you can generate |
