User Tools
Site Tools
asc:promc:introduction
Differences
Link to this comparison view
Next revision
Previous revision
asc:promc:introduction [2016/03/25 20:51]
asc [Available conversions]
asc:promc:introduction [2017/03/22 11:29] (current)
asc [Available ProMC commands]
Line 82: Line 82:
 {{:asc:promc:sizereduction.png?500|}} {{:asc:promc:sizereduction.png?500|}}
Line 163: Line 154:
 |   promc_code                       | generates source files using "proto" directory. C++ code is generated in the directory src/, while Java code in the directory java/src | |   promc_code                       | generates source files using "proto" directory. C++ code is generated in the directory src/, while Java code in the directory java/src |
 |   promc_log <file>                 | extracts the log file "logfile.txt" (if attached to the ProMC file) | |   promc_log <file>                 | extracts the log file "logfile.txt" (if attached to the ProMC file) |
-|   hepmc2promc <HEPMC input>  <ProMC output> "description"               | converts HepMC file to ProMC file |
-|   promc2hepmc <ProMC input>  <HepMC output>                | converts ProMC file to HEPMC file |
-|   promc2hepevt <ProMC input>  <HepEVT output>                | converts ProMC file to HEPEVT file |
-|   promc2stdhep <ProMC input>  <StdHep output>                | converts ProMC file to StdHep file |
-|   promc2lcio <ProMC input>  <LCIO output>                    | converts ProMC file to LCIO file |
-|   stdhep2promc <StdHEP input>  <ProMC output>                | converts StdHEP file to ProMC file |
 |   promc_split <ProMC file>  N   | splits a ProMC files into N files in the directory "out" | |   promc_split <ProMC file>  N   | splits a ProMC files into N files in the directory "out" |
Line 247: Line 232:
 |   promc2stdhep <ProMC input>  <STDHEP output>                | converts ProMC file to STDHEP | |   promc2stdhep <ProMC input>  <STDHEP output>                | converts ProMC file to STDHEP |
 |   promc2lcio <ProMC input>  <LCIO output>                | converts ProMC file to LCIO | |   promc2lcio <ProMC input>  <LCIO output>                | converts ProMC file to LCIO |
-|   lhe2promc <LHE input>  <ProMC output>                | converts LHEF file to ProMC |+|   lhe2promc <LHE input>  <ProMC output>                | converts LHEF (TXT) file with MC events to ProMC |
 +|   txt2promc <TXT input>  <ProMC output>                | converts TXT file with MC events to ProMC |
 | java -cp .:browser_promc.jar hepsim.MixPileup pN signal.promc minbias.promc output.promc | Pileup mixer. Mix N random events using a Poisson distribution with signal events | | java -cp .:browser_promc.jar hepsim.MixPileup pN signal.promc minbias.promc output.promc | Pileup mixer. Mix N random events using a Poisson distribution with signal events |
asc/promc/introduction.1458939079.txt.gz · Last modified: 2016/03/25 20:51 by asc
