asc:tutorials:2014october_connect [2014/10/10 15:24] asc [Lesson 6: Using HTCondor and Tier2] |
asc:tutorials:2014october_connect [2014/10/10 15:26] asc [Lesson 6: Using HTCondor and Tier2] |
Line 214: | Line 214: | ||
In this example we will use HTCondor workload management system to send the job to be executed in a queue at a Tier3 farm. For this example we will start from the directory lesson 4, so if you did not do the lesson 4 please do that one first and verify that your code runs locally. | In this example we will use HTCondor workload management system to send the job to be executed in a queue at a Tier3 farm. For this example we will start from the directory lesson 4, so if you did not do the lesson 4 please do that one first and verify that your code runs locally. | ||
Start from the new shell and set up environment, | Start from the new shell and set up environment, | ||
- | startJob.sh | ||
<file bash startJob.sh> | <file bash startJob.sh> | ||
Line 272: | Line 271: | ||
- | ./ | + | chmod 755 ./ |
