User Tools
Site Tools
asc:tutorials:eclipse
Differences
Link to this comparison view
Next revision
Previous revision
asc:tutorials:eclipse [2014/10/29 14:55]
aparamonov
asc:tutorials:eclipse [2014/10/29 21:20]
asc
Line 1: Line 1:
 ====== Eclipse ====== ====== Eclipse ======
Line 8: Line 10:
   - If you do not have Java, please download and install it. Eclipse needs it.   - If you do not have Java, please download and install it. Eclipse needs it.
   - Download "Eclipse IDE for C/C++ Developers" from http://www.eclipse.org/downloads/   - Download "Eclipse IDE for C/C++ Developers" from http://www.eclipse.org/downloads/
-  - Extract folder "eclipse" to a location where you want to store the executables.  E.G. C:\Program Files\+  - Extract folder "eclipse" to a location where you want to store the executable.  E.G. C:\Program Files\
   - Enter the folder and execute "eclipse". It will ask you for location of the workspace. That's where the source code is stored.   - Enter the folder and execute "eclipse". It will ask you for location of the workspace. That's where the source code is stored.
 +<note tip>For ANL, eclipse is installed in /share/sl6/eclipse/ directory.</note>
 ===== Install SVN plugins ===== ===== Install SVN plugins =====
Line 15: Line 19:
   - Run Eclipse and select Help > Install New Software... from the main menu.   - Run Eclipse and select Help > Install New Software... from the main menu.
   - Enter "http://download.eclipse.org/releases/juno" in "work with" and click "Add..."   - Enter "http://download.eclipse.org/releases/juno" in "work with" and click "Add..."
-  - Select "Collaboration --> Subversive SVN team provider" and install it.+  - Select "Collaboration -> Subversive SVN team provider" and install it.
   - Restart Eclipse   - Restart Eclipse
-  - Select Help > Install New Software... from the main menu. +  - Select Help -> Install New Software... from the main menu.
-  - Enter http://community.polarion.com/projects/subversive/download/eclipse/4.0/luna-site/ in "work with" and click "Add..."+  - Enter [[http://community.polarion.com/projects/subversive/download/eclipse/4.0/luna-site/]] in "work with" and click "Add..."
   - Select "Subversive SVN Connectors" and "SVN Kit" and install them.   - Select "Subversive SVN Connectors" and "SVN Kit" and install them.
   - Restart Eclipse.   - Restart Eclipse.
Line 25: Line 29:
   - Window -> Open perspective -> SVN Repository Exploring   - Window -> Open perspective -> SVN Repository Exploring
-  - Add New Repository Location. Enter svn+ssh://svn.cern.ch/reps/atlasoff as URL. Use your CERN username and password.+  - Add New Repository Location. Enter [[svn+ssh://svn.cern.ch/reps/atlasoff]]
 +  - Use your CERN username and password.
   - You can also do that to your private SVN repository.   - You can also do that to your private SVN repository.
   - Select AnalysisSUSY -> trunk -> packages.rc   - Select AnalysisSUSY -> trunk -> packages.rc
Line 34: Line 39:
 ===== Import a package from SVN ===== ===== Import a package from SVN =====
   - Return to "C/C++ Perspective": click the icon in the upper-right corner of the window.   - Return to "C/C++ Perspective": click the icon in the upper-right corner of the window.
Line 42: Line 46:
   - Select "Check out as a project with the name specified:". The project will appear in the Project Explorer.   - Select "Check out as a project with the name specified:". The project will appear in the Project Explorer.
   - Go to src --> SUSYToolsAlg.cxx and double-click on the file.   - Go to src --> SUSYToolsAlg.cxx and double-click on the file.
-  - Right-click on the project name. Select "New --> Covert to a C/C++ Project".+  - Right-click on the project name. Select "New -> Covert to a C/C++ Project".
   - Select "C Project. Uncheck "Specify project type".   - Select "C Project. Uncheck "Specify project type".
   - Now the syntax checking, indexing, and autocomplete are enabled.   - Now the syntax checking, indexing, and autocomplete are enabled.
 +===== Edit the code  =====
 +  - Press Shift+Ctrl+F
 +  - It will auto-alight the code.
 +  - Go to line 128 and type "jets_" and press "Ctrl+Space". The auto-coplete will finish the name.
 +  - Delete "jets_shallowCopy" and enter ";" instead.
 +  - Let's commit that into the SVN repository.
 +  - Right-click on SUSYToolsAlg.cxx and select "Team -> Commit...".
 +  - Select "Yes." Enter your comment and click "OK".
 +  - Ops.. we do not have permissions to do that.
 +  - Well, that is how you synchronize your code with a repository.
 +  - Right-click on SUSYToolsAlg.cxx and select "Team -> Revert". The file is returned to the original state.
 +===== Add libraries  =====
 +  - You may want to keep your code aware of external libraries (e.g. ROOT).
asc/tutorials/eclipse.txt · Last modified: 2014/10/29 21:20 by asc
