User Tools
Site Tools
asc:workbook_proof
<<back
Working with PROOF
You can use PROOF on the cluster. It is advised to use 6-7 cores when using PROOF line (since we have 8 physical cores per server).
You can find some ATLAS instructions here:
https://twiki.cern.ch/twiki/bin/viewauth/AtlasProtected/PhysicsAnalysisWorkBookRel16D3PDAnalysisExample
https://twiki.cern.ch/twiki/bin/viewauth/AtlasProtected/PhysicsAnalysisWorkBookPROOF
There is an example in
/users/chakanau/public/proof/
(kindly provided by Duong Nguyen)
How it works:
cd Ana_proof
./RootCore/configure
source RootCore/scripts/setup.sh
RootCore/scripts/find_packages.sh
RootCore/scripts/clean.sh
RootCore/scripts/compile.sh
python runSkimAna.py
First, we compile RootCore libraries. Then we run “runSkimAna.py”. The actual C++ program is runRootCore.C There are proof or non-proof option at line 55, 56 in runSkimAna.py.
Jet example
A typical example to work with jets is
/users/chakanau/public/proof/jets
Compile the code “make” and run A_RUN_TEST.
The main code is “main.cxx” where you can say tell yes“ to the prooflite option. We fill jet histograms in src/Jets.cxx” (the event loop). src/Truth.cxx - keep track the truth info. Histogram are defined in inc/Ana.h and src/IniHistograms.cxx. The output is in out/output.root.
asc/workbook_proof.txt · Last modified: 2013/05/30 18:53 (external edit)
