community:hepsim [2016/09/12 02:13] asc |
community:hepsim [2017/09/30 14:36] asc |
Line 1: | Line 1: | ||
- | ====== HepSim | + | <note important> |
+ | http:// | ||
- | HepSim | + | |
- | The HepSim repository was started at ANL during the US long-term planning study of the American Physical Society’s Division of Particles and Fields (Snowmass 2013) with the goal to create references to truth-level | + | |
- | Event data samples are createdusing: | + | [[http:// |
+ | The [[http:// | ||
- | * BlueGene/Q supercomputer of the Argonne Leadership Computing Facility (with BG@HEPlib | + | * BlueGene/Q supercomputer of the Argonne Leadership Computing Facility ([[hpc: |
- | * Open-science grid (OSG) and OSG CI Connect (" | + | * [[https:// |
* ATLAS Connect virtual cluster service (" | * ATLAS Connect virtual cluster service (" | ||
* Argonne’s Laboratory Computing Resource Center (LCRC) (" | * Argonne’s Laboratory Computing Resource Center (LCRC) (" | ||
Line 16: | Line 18: | ||
* STASH2 storage at OSG CI Connect | * STASH2 storage at OSG CI Connect | ||
* FAXBOX storage at ATLAS Connect | * FAXBOX storage at ATLAS Connect | ||
- | * Science | + | * [[https:// |
* MC.HEP server at ASC ANL | * MC.HEP server at ASC ANL | ||
- | + | This repository was created following | |
- | + | the guidelines and principles | |
- | Monte Carlo events are generated using the | + | [[http:// |
- | + | for unclassified | |
- | The Monte Carlo files (truth-level, | + | |
- | can be accessed from the [[http:// | + | |
====== For HepSim users ====== | ====== For HepSim users ====== | ||
If you are a HepSim user, start from here. | If you are a HepSim user, start from here. | ||
Line 43: | Line 43: | ||
Here are several links to extending this Wiki for particular detector-performance topics: | Here are several links to extending this Wiki for particular detector-performance topics: | ||
* [[fcs: | * [[fcs: | ||
- | * [[fcs:sid:intro|SID detector studies]] - explains how to analyses data for the SiD detector (ILC) | + | * [[fcs: |
- | * [[fcs:cepc:intro|CEPC detector studies]] - shows some results with full simulations for CEPC | + | * [[fcs: |
- | * [[fcs:eic:intro|EIC detector studies]] - shows some results with full simulations for EIC | + | * [[fcs: |
* [[vlhc: | * [[vlhc: | ||
Line 55: | Line 56: | ||
====== For developers ====== | ====== For developers ====== | ||
If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | ||
Line 60: | Line 62: | ||
* [[community: | * [[community: | ||
- | * [[community: | + | * [[community: |
Line 67: | Line 69: | ||
- | ===== How to cite ===== | + | |
- | + | ===== Public results ===== | |
+ | * [[https:// | ||
+ | ===== Contributions ===== | ||
+ | ====== How to cite ====== | ||
If you use HepSim event samples, Python/ | If you use HepSim event samples, Python/ | ||
Line 74: | Line 89: | ||
- | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// | + | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// |
<hidden Click here to display BibTeX article entry> | <hidden Click here to display BibTeX article entry> | ||
Line 93: | Line 108: | ||
- | ===== Public results ===== | ||
- | * [[https:// | ||
- | ===== Contributions ===== | ||
====== Acknowledgement ====== | ====== Acknowledgement ====== | ||
The current work is supported | The current work is supported |
