community:hepsim [2016/09/12 02:21] asc [HepSim manual] |
community:hepsim [2016/11/06 19:16] asc [Physics and detector studies] |
Line 1: | Line 1: | ||
- | HepSim is a public repository with Monte Carlo simulated events for high-energy physics (HEP) experiments. | + | [[http:// |
- | The HepSim repository was started at ANL during the US long-term planning study of the American Physical Society’s Division of Particles and Fields (Snowmass 2013) with the goal to create references to truth-level | + | The [[http:// |
* BlueGene/Q supercomputer of the Argonne Leadership Computing Facility ([[hpc: | * BlueGene/Q supercomputer of the Argonne Leadership Computing Facility ([[hpc: | ||
Line 18: | Line 18: | ||
This repository was created following | This repository was created following | ||
- | the guidelines and principles of | + | the guidelines and principles of the |
[[http:// | [[http:// | ||
for unclassified and otherwise unrestricted scientific data in digital formats. | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
- | The HepSim Monte Carlo data (truth-level, | ||
- | can be accessed from the [[http:// | ||
====== For HepSim users ====== | ====== For HepSim users ====== | ||
If you are a HepSim user, start from here. | If you are a HepSim user, start from here. | ||
Line 41: | Line 39: | ||
Here are several links to extending this Wiki for particular detector-performance topics: | Here are several links to extending this Wiki for particular detector-performance topics: | ||
* [[fcs: | * [[fcs: | ||
- | * [[fcs:sid:intro|SID detector studies]] - explains how to analyses data for the SiD detector (ILC) | + | * [[fcs: |
- | * [[fcs:cepc:intro|CEPC detector studies]] - shows some results with full simulations for CEPC | + | * [[fcs: |
- | * [[fcs:eic:intro|EIC detector studies]] - shows some results with full simulations for EIC | + | * [[fcs: |
* [[vlhc: | * [[vlhc: | ||
Line 53: | Line 52: | ||
====== For developers ====== | ====== For developers ====== | ||
If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | ||
Line 58: | Line 58: | ||
* [[community: | * [[community: | ||
- | * [[community: | + | * [[community: |
Line 65: | Line 65: | ||
- | ===== How to cite ===== | + | |
- | + | ===== Public results ===== | |
+ | * [[https:// | ||
+ | ===== Contributions ===== | ||
+ | ====== How to cite ====== | ||
If you use HepSim event samples, Python/ | If you use HepSim event samples, Python/ | ||
Line 72: | Line 85: | ||
- | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// | + | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// |
<hidden Click here to display BibTeX article entry> | <hidden Click here to display BibTeX article entry> | ||
Line 91: | Line 104: | ||
- | ===== Public results ===== | ||
- | * [[https:// | ||
- | ===== Contributions ===== | ||
====== Acknowledgement ====== | ====== Acknowledgement ====== | ||
The current work is supported | The current work is supported |
