community:hepsim [2016/10/25 20:55] asc [For developers] |
community:hepsim [2017/09/30 14:36] asc |
Line 1: | Line 1: | ||
+ | <note important> | ||
+ | http:// | ||
Line 44: | Line 48: | ||
* [[fcs: | * [[fcs: | ||
- | * [[fcs:sid:intro|SID detector studies]] - explains how to analyses data for the SiD detector (ILC) | + | * [[fcs: |
- | * [[fcs:cepc:intro|CEPC detector studies]] - shows some results with full simulations for CEPC | + | * [[fcs: |
- | * [[fcs:eic:intro|EIC detector studies]] - shows some results with full simulations for EIC | + | * [[fcs: |
* [[vlhc: | * [[vlhc: | ||
Line 65: | Line 69: | ||
- | ===== How to cite ===== | + | |
- | + | ===== Public results ===== | |
+ | * [[https:// | ||
+ | ===== Contributions ===== | ||
+ | ====== How to cite ====== | ||
If you use HepSim event samples, Python/ | If you use HepSim event samples, Python/ | ||
Line 91: | Line 108: | ||
- | ===== Public results ===== | ||
- | * [[https:// | ||
- | ===== Contributions ===== | ||
====== Acknowledgement ====== | ====== Acknowledgement ====== | ||
The current work is supported | The current work is supported |
