community:hepsim:usage_download [2016/09/12 14:14] asc [Data formats] |
community:hepsim:usage_download [2016/10/12 02:22] asc [Downloading files after detector simulation] |
Line 3: | Line 3: | ||
- | Truth-level data are stored in a platform-independent format called [[http:// | + | Truth-level |
supported by popular programming languages (C++, Java, Python) on major operating system (Windows, Mac, Linux, etc.). | supported by popular programming languages (C++, Java, Python) on major operating system (Windows, Mac, Linux, etc.). | ||
Open access to such files via the http protocol is the central element | Open access to such files via the http protocol is the central element | ||
Line 51: | Line 51: | ||
- | Use the event-record browser to view separate events, cross sections and log files. On Linux/Mac, use: | + | Use the event-record browser to view separate |
Line 79: | Line 79: | ||
- | One can check the consistency of the file and additional information as: | + | Check the consistency of the EVGEN file and additional information as: |
Line 236: | Line 236: | ||
hs-get http:// | hs-get http:// | ||
- | All these examples will download all files from the " | + | All these examples will download all files from the " |
+ | <note important> | ||
You can stop downloading using [Ctrt-D]. Next time you start it, it will continue the download. | You can stop downloading using [Ctrt-D]. Next time you start it, it will continue the download. | ||
Line 296: | Line 298: | ||
hs-get | hs-get | ||
- | As before, one can also download the files using the URL: | + | |
+ | As before, one can also download the files using the URL approach: | ||
hs-ls http:// | hs-ls http:// | ||
+ | Note that the reconstruction tag " | ||
+ | As before, the URL can be taken from the list with mirrors. For example, if you want to download | ||
+ | <code bash> | ||
+ | hs-ls http:// | ||
+ | hs-get http:// | ||
