community:hepsim:usage_download [2016/09/17 11:53] asc |
community:hepsim:usage_download [2016/10/12 20:59] asc [Downloading truth-level files] |
Line 3: | Line 3: | ||
Truth-level (EVGEN) data are stored in a platform-independent format called [[http:// | Truth-level (EVGEN) data are stored in a platform-independent format called [[http:// | ||
supported by popular programming languages (C++, Java, Python) on major operating system (Windows, Mac, Linux, etc.). | supported by popular programming languages (C++, Java, Python) on major operating system (Windows, Mac, Linux, etc.). | ||
Line 228: | Line 228: | ||
hs-get tev100_higgs_ttbar_mg5 data | hs-get tev100_higgs_ttbar_mg5 data | ||
+ | You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files. | ||
Alternatively, | Alternatively, | ||
Line 236: | Line 238: | ||
hs-get http:// | hs-get http:// | ||
- | All these examples will download all files from the " | + | All these examples will download all files from the " |
+ | <note important> | ||
You can stop downloading using [Ctrt-D]. Next time you start it, it will continue the download. | You can stop downloading using [Ctrt-D]. Next time you start it, it will continue the download. | ||
Line 296: | Line 300: | ||
hs-get | hs-get | ||
- | As before, one can also download the files using the URL: | + | |
+ | As before, one can also download the files using the URL approach: | ||
hs-ls http:// | hs-ls http:// | ||
+ | Note that the reconstruction tag " | ||
+ | As before, the URL can be taken from the list with mirrors. For example, if you want to download | ||
+ | <code bash> | ||
+ | hs-ls http:// | ||
+ | hs-get http:// | ||
