community:hepsim:usage_full [2016/04/28 15:21] asc |
community:hepsim:usage_full [2017/09/30 14:35] (current) asc |
Line 1: | Line 1: | ||
+ | <note important> | ||
+ | http:// | ||
- | ====== Full detector simulation | + | ====== Full detector simulations |
+ | Currently, the Geant4-based | ||
+ | use these files for the " | ||
+ | To process SLCIO files, you will need [[http:// | ||
+ | The files with full simulations are located under the " | ||
+ | Here how you can find all samples that have " | ||
+ | The description of the detector tags is given in [[community: | ||
+ | If you need to find all files | ||
+ | for a give tag, say rfull005, use this command: | ||
+ | <code bash> | ||
+ | hs-find tev10mumu%rfull005 | ||
+ | which searches for all samples with the dataset name " | ||
+ | Then download a selected sample as: | ||
+ | hs-get tev10mumu_pythia6_zprime10tev_qqbar%rfull005 | ||
+ | The [[http:// | ||
+ | Each " | ||
+ | The physics performance studies based on full simulation files from HepSim | ||
+ | are [[fcs: | ||
+ | ====== Processing LCIO files ====== | ||
+ | To perform data analysis using LCIO files, use the [[https:// | ||
+ | The installation does not have external dependencies besides Java. Make sure Java7 and above is installed. | ||
+ | Then run these commands to install the package using Linux/Mac with the " | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | The last command optimizes Java packages for the Python language. | ||
+ | Now you are ready to run over any file with truth-level and datector-simulation files, such as LCIO and ProMC. This program can be used for: | ||
+ | * Downloading and searching HepSim data | ||
+ | * Processing ProMC files from HepSim | ||
+ | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
+ | * Data analysis (jets, physics vectors, histogram packages) | ||
+ | * Visualisation of reconstructed events using Wired4 display | ||
+ | You can find more details in [[asc: | ||
+ | The standard set of containers is available from the LCIO files posted on HepSim. Read | ||
+ | [[http:// | ||
+ | [[http:// | ||
+ | Look the Java API definition of the needed objects in [[http:// | ||
+ | BeamCalHits | ||
+ | CalorimeterHitRelations | ||
+ | EM_BARREL | ||
+ | EM_ENDCAP | ||
+ | EcalBarrelHits | ||
+ | EcalEndcapHits | ||
+ | HAD_BARREL | ||
+ | HAD_ENDCAP | ||
+ | HcalBarrelHits | ||
+ | HcalEndcapHits | ||
+ | HelicalTrackHitRelations | ||
+ | HelicalTrackHits | ||
+ | HelicalTrackMCRelations | ||
+ | LumiCalHits | ||
+ | MCParticle | ||
+ | MUON_BARREL | ||
+ | MUON_ENDCAP | ||
+ | MuonBarrelHits | ||
+ | MuonEndcapHits | ||
+ | PandoraPFOCollection | ||
+ | ReconClusters | ||
+ | SiTrackerBarrelHits | ||
+ | SiTrackerEndcapHits | ||
+ | SiTrackerForwardHits | ||
+ | SiVertexBarrelHits | ||
+ | SiVertexEndcapHits | ||
+ | StateAtECal | ||
+ | StateAtEnd | ||
+ | StateAtStart | ||
+ | TKR_RawTrackerHits | ||
+ | TKR_TrackerHits | ||
+ | Tracks | ||
+ | VXD_RawTrackerHits | ||
+ | VXD_TrackerHits | ||
+ | ====== Using C++/ROOT with LCIO ====== | ||
+ | If you need to read LCIO files in C++ code with ROOT/ | ||
+ | cd lcio-cpp; make | ||
+ | It will compile " | ||
+ | ====== Visualizing events with Jas+Wired ====== | ||
+ | You can run Jas+Wired to visualize the simulated events. | ||
+ | ./jaspp | ||
+ | This will start a Jas3-like environment | ||
+ | Then copy the detector geometry file from the [[http:// | ||
+ | This will create a directory " | ||
+ | Now we can visualize the detector as **[File]-[Open data source]-[HepRep]** XML and select the file " | ||
+ | This is how to do this using the command line: | ||
+ | You will see the detector layout: | ||
+ | Now, we will read the event: Open any *.slcio file you copied from HepSim as | ||
+ | **[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | ||
+ | Now press [Go] again to look at next event. | ||
+ | If you want to see how data records are organized inside the slcio file, | ||
+ | do this **[File]-[New]-[LCSim Event browser]** | ||
+ | Generally, when you open a SLCIO file from the HepSim, you do not need to load the geometry file. The geometry file will be downloaded automatically from HepSim and will be put to " | ||
+ | ====== Visualizing geometry using ROOT ====== | ||
+ | (contribution from N.Nikiforou): | ||
+ | You can also visualize the detector using ROOT. Here are a few steps: | ||
+ | Locate the file detector.gdml inside the file detector.zip (where " | ||
+ | <hidden show more details here> | ||
+ | This file is created using this command during the detector design stage | ||
+ | slic -g detector.lcdd -G detector.gdml | ||
+ | Once you have the GDML file, you can use ROOT to visualize it. You just | ||
+ | need to make sure the ROOT installation has openGL/GDML support (CERN | ||
+ | AFS installations have it for sure). At the ROOT prompt do: | ||
+ | <code cpp> | ||
+ | TGeoManager:: | ||
+ | gGeoManager-> | ||
+ | This should popup an OpenGL display with the detector which you can | ||
+ | clip, pan, rotate etc. You will the image as shown here: | ||
+ | ====== People ====== | ||
+ | * S.Chekanov (ANL, main developer) | ||
+ | * E.May (ANL, debugging, Wired4) | ||
+ | ====== Additional help ====== | ||
+ | * [[http:// | ||
+ | * [[https:// | ||
- | Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | ||
- | use these files for the " | ||
- | The physics performance studies are [[fcs: | ||
- | How to convert ProMC to LCIO files is described in | ||
- | [[community: |
