community:hepsim:usage_full [2016/04/29 00:08] asc [Full detector simulations] |
community:hepsim:usage_full [2017/09/30 14:35] (current) asc |
Line 1: | Line 1: | ||
+ | <note important> | ||
+ | http:// | ||
Line 8: | Line 13: | ||
The files with full simulations are located under the " | The files with full simulations are located under the " | ||
- | Here how you can find all samples that have " | + | Here how you can find all samples that have " |
+ | The description of the detector tags is given in [[community: | ||
+ | If you need to find all files | ||
for a give tag, say rfull005, use this command: | for a give tag, say rfull005, use this command: | ||
