community:refhepsim_analysis [2015/10/17 12:27] asc [Histograms and plots] |
community:refhepsim_analysis [2015/12/03 16:37] asc [Lorentz particles and Jets] |
Line 5: | Line 5: | ||
For C++/ROOT, please refer [[asc: | For C++/ROOT, please refer [[asc: | ||
- | To ensure platform independence and a possibility to run programs using web browsers, validation programs are written in Jython, which is an implementation of the Python language on the Java platform. | + | To ensure platform independence and a possibility to run programs using web browsers |
Look at several links: | Look at several links: | ||
- | * [[http:// | + | * [[http:// |
Line 203: | Line 203: | ||
print "pT of a leading jet =", | print "pT of a leading jet =", | ||
- | To build anti-kT jets, we use [[http:// | + | To build anti-kT jets, we use [[http:// |
+ | The description of this algorithm is given in [[http:// | ||
+ | It is a similar to FastJet N*N algorithm and typically shows | ||
a performance similar to the C++ analogue. Tests indicate that the JetN2 clustering algorithm is about twice slower that C++, but by a factor 20 faster than the traditional N^3 jet clustering algorithms. You can find benchmarking results in [[https:// | a performance similar to the C++ analogue. Tests indicate that the JetN2 clustering algorithm is about twice slower that C++, but by a factor 20 faster than the traditional N^3 jet clustering algorithms. You can find benchmarking results in [[https:// | ||
Look at a typical example of jet clustering in the [[http:// | Look at a typical example of jet clustering in the [[http:// | ||
Line 262: | Line 264: | ||
stored inside ProMC data files: | stored inside ProMC data files: | ||
- | ==== Histograms and plots ==== | + | ===== Histograms and plots ===== |
- | + | * [[http:// | |
+ | * [[http:// | ||
See also other math and graphics classes in the [[http:// | See also other math and graphics classes in the [[http:// | ||
- | ==== Lorentz particles and Jets ==== | + | ===== Lorentz particles and Jets ===== |
Line 276: | Line 279: | ||
Line 285: | Line 288: | ||
You can build the standard kt-jets using [[http:// | You can build the standard kt-jets using [[http:// | ||
- | [[http:// | + | [[http:// |
+ | ===== Working with ProMC files ===== | ||
+ | Also, look at the ProMC Java API that is used to store data: | ||
Line 296: | Line 303: | ||
information on event weights and uncertainties. | information on event weights and uncertainties. | ||
- | The project uses the core of [[http:// | + | The project uses the community edition |
