fcs:cepc:intro [2016/03/21 20:18] asc |
fcs:cepc:intro [2016/04/08 16:54] asc [Wired Visualization] |
Line 1: | Line 1: | ||
+ | [[fcs: | ||
===== CEPC detector studies ===== | ===== CEPC detector studies ===== | ||
+ | **People:** S.Chekanov, M.Demarteau | ||
This wiki explains how to view electron-proton collision events for CEPC. | This wiki explains how to view electron-proton collision events for CEPC. | ||
To analyse events for such studies, install [[http:// | To analyse events for such studies, install [[http:// | ||
Line 116: | Line 120: | ||
+ | ====== Wired Visualization ====== | ||
+ | You can run Jas+Wired to visualize the simulated events. | ||
+ | <code bash> | ||
+ | jaspp sifcch1.heprep | ||
+ | You can download the heprep file from [[http:// | ||
+ | Alternatively, | ||
+ | You will see the detector layout. | ||
+ | Now, we will read the event: Open any *.slcio file you copied from HepSim as | ||
+ | **[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | ||
+ | Now press [Go] again to look at next event. | ||
+ | If you want to see how data records are organized inside the slcio file, | ||
+ | do this **[File]-[New]-[LCSim Event browser]** | ||
+ | To view " | ||
