fcs:cepc:intro [2016/03/23 01:23] asc |
fcs:cepc:intro [2016/04/08 16:54] asc [Wired Visualization] |
Line 120: | Line 120: | ||
+ | ====== Wired Visualization ====== | ||
+ | You can run Jas+Wired to visualize the simulated events. | ||
+ | <code bash> | ||
+ | jaspp sifcch1.heprep | ||
+ | You can download the heprep file from [[http:// | ||
+ | Alternatively, | ||
+ | You will see the detector layout. | ||
+ | Now, we will read the event: Open any *.slcio file you copied from HepSim as | ||
+ | **[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | ||
+ | Now press [Go] again to look at next event. | ||
+ | If you want to see how data records are organized inside the slcio file, | ||
+ | do this **[File]-[New]-[LCSim Event browser]** | ||
+ | To view " | ||
