fcs:cepc:intro [2016/03/26 03:47] asc [Jet energy resolutions] |
fcs:cepc:intro [2016/04/08 16:54] asc [Wired Visualization] |
Line 122: | Line 122: | ||
====== Wired Visualization ====== | ====== Wired Visualization ====== | ||
- | You can run Jas+Wired to visualize the simulated events. | + | You can run Jas+Wired to visualize the simulated events. |
jaspp sifcch1.heprep | jaspp sifcch1.heprep | ||
- | You can download the heprep file from [[[[http:// | + | You can download the heprep file from [[http:// |
Alternatively, | Alternatively, | ||
You will see the detector layout. | You will see the detector layout. | ||
- | Now, we will read the event: Open any *.slcio file you copied from HepSim as | + | Now, we will visualize a single |
**[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | **[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | ||
